Pocket GPS World :: View topic - Sticking On/Off button (x40)
hijacker
PostPosted: Fri Feb 03, 2012 9:09 pm    Post subject: Sticking On/Off button (x40) Reply with quote
My 940 has developed a sticking on/off button.
Does anyone know if this is an easy/cheap fix? I'm willing to dismantle it myself if necessary.
Thanks.
TT GO 1005
PostPosted: Fri Feb 03, 2012 9:19 pm    Post subject: Reply with quote
If you fancy taking the unit apart, do a forum search for battery changing as the disassembly steps will be the same.
It's possible the switch itself is OK, but its the plastic actuator that's sticking.
If not, the switch itself is a 20p part (if you can source a replacement), but it is a surface-mount component on a multilayer printed circuit board.
Unless you are used to working on such things, then I'm afraid you won't have the equipment needed to do the micro-soldering required to swap the switch.
"Settling in nicely" ;-)
JockTamsonsBairn
PostPosted: Fri Feb 03, 2012 11:21 pm    Post subject: Reply with quote
I can't find anything here, but Googling "Tomtom 940 strange issue - looking for any ideas - Page 2" throws up a thread that you and Mike contributed to on another forum. Can we cross-post links to the other forums?
Jock
hijacker
PostPosted: Fri Feb 03, 2012 11:52 pm    Post subject: Reply with quote
thanks for replies.
i'll open it up and take a look.
TT GO 1005
PostPosted: Sat Feb 04, 2012 12:51 am    Post subject: Reply with quote
There's this...
x40/ x50 Battery Change
Yes no problem....
JockTamsonsBairn
PostPosted: Sun Feb 05, 2012 3:52 pm    Post subject: Reply with quote
Andy_P wrote:
There's this...
Well searched! Clap Embarassed
Jock
hijacker
PostPosted: Sun Sep 16, 2012 10:48 am    Post subject: Reply with quote
Since I first started this thread the button has finally failed.
Whenever pressed it remains down, right of centre more than anything, causing the device to be in a constant state of reboot.
I've removed the button leaving the 940 only operational via the small button on the circuit board itself which is not a long term solution for me.
Does anyone know of any repair options here or should I start my search for an alternative sat nav now?
TT GO 1005
justbrowsing
PostPosted: Sun Sep 16, 2012 11:13 am    Post subject: Reply with quote
You could google "tomtom repairs" & get a few quotes as it's going to be cheaper than a new device for sure
hijacker
PostPosted: Sun Sep 16, 2012 11:17 am    Post subject: Reply with quote
I did get one quote of £50! I'm not really looking to spend much on my 940 now given it's age. Sods law I pay for a repair and something else fails the following week.
TT GO 1005
Greenglide
PostPosted: Sun Sep 16, 2012 12:30 pm    Post subject: Reply with quote
Can you not use eBay (or similar auction site) to obtain a cheap, possibly non functional, TT Go x40 (any 40 series would do) and pinch the plastic switch out of that?
Assuming it is just the button failed, not the switch.
TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
TomTom Go 520T, V8.351, TTS V7, Map GB & Ireland 855.2884
Nokia 5800 with Google Maps & OVI Maps
Google Nexus One with Google Maps & NDrive
aerotec
PostPosted: Sun Sep 16, 2012 3:44 pm    Post subject: Reply with quote
I sometimes get my button stocking but find that if I hold backward pressure so the button is pushed towards the rear of the device I am able to power it on/or off without it sticking. If the button is jamming on the housing has anyone tried a drop of light oil to lubricate it?
jonial
PostPosted: Sun Sep 16, 2012 4:07 pm    Post subject: Reply with quote
A bit of a long shot but try a few drops of isopropyl alcohol on the button.
It cleared a sticking shutter release button on my camera
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
hijacker
PostPosted: Sun Sep 23, 2012 10:53 am    Post subject: Reply with quote
Finally opened up the 940......and found a small piece of the black plastic ON/OFF button still attached inside the case. The two small pieces either side of this button are located in the case and give the button its springiness.
TT GO 1005
23.012 (08 Jan 25)
