Pocket GPS World :: View topic - Navigator 3.03
Navigator 3.03
Rmac
PostPosted: Mon Aug 23, 2004 5:23 pm    Post subject: Navigator 3.03 Reply with quote
I have an IPAQ 2210 and would like to purchase TT BT GPS and navigator 3 but observe that ther are many problems with this setup - lockups and BT dropout - I see that TT3 is now at V3.03 which TT say will cure this problem - any feedback?
sland
PostPosted: Mon Aug 23, 2004 6:00 pm    Post subject: Reply with quote
It seems to sort things for some and not for others. However, disabling POIs from being displayed (not used just displayed) does seem to overcome the problem for all (?willing to be corrected here?)
HTH?
Rgds,
Mike
SteveW
PostPosted: Mon Aug 23, 2004 9:31 pm    Post subject: Reply with quote
I think also it has highlighted the need for faster SD cards.
Steve.
PostPosted: Mon Aug 23, 2004 10:43 pm    Post subject: Reply with quote
If you have a 2210 the simple answer is to use CF cards for map storage as this resolves all the BT drop-out problems. You can still use SD for all other data.
Rmac
PostPosted: Tue Aug 24, 2004 6:26 pm    Post subject: Reply with quote
Many thanks for replies - I feel I have enough confidence to go ahead and purchase the TT BT GPS - will update you when I have some results
iancjc
PostPosted: Tue Aug 24, 2004 7:28 pm    Post subject: Reply with quote
go ahead - I think you'll be impressed.
I like many others have a 2210 and bt gps and don't suffer any problems at all - it's human nature to post when you have problems not when it's all working ok.
I have my maps on a mixture of sd card - uk and mre - and cf - france - and notice no difference between the 2 - I had hell and all problems with a sandisk ultra sd card (the fast ones) but now stick with an i-o data japan made one - which although normal speed is very fast (= to a panasonic card I also use)
good luck
Ian
TTN6.03 tomtom 7.xx (one)
Rmac
PostPosted: Wed Sep 01, 2004 11:52 am    Post subject: Reply with quote
I have now purchases Tomtom Bluetooth GPS and Navigator v 3.03 from Global Positioning Systems and have several problems - been in use for 4 days:
No instructions with GPS so assume the following:
Blue flashing - no connection
Blue On - PDA/GPS conection
Green flashing - sat lock
Green off - no sat lock
Red On - Charging
Red Off - fully charged
PDA connects via Bluetooth manager - Blue On GPS but no GPS status on PDA and no connection indication on moving line - can only restore via soft reset - PDA says all connected - this has happened several times!!!
PDA looses GPS link and requires to be set via Bluetooth manager - this has happened several times !!
GPS takes 20 mins to sat lock - happened several times
System is good when working but fails far too often
Have sent above message to Tomtom
Using CF for maps - makes no difference if POI is on or off
Questions
Do I have to connect via BT manager at every switch on - remembers most times and comes up on Navigator on switch on - I have just bee switching off GPS and PDa without exiting navigator but works most of the time? Little instructions with the GPS on operational modes
Regards
Ralph Mackenzie
arndale
PostPosted: Wed Sep 01, 2004 1:59 pm    Post subject: Reply with quote
Hi Ralph,
The description of the lights seems correct to me.
As for needing to start BT Manager on some occassions, I used to wonder about that, but it seems that if you exit Tom Tom before turning the PDA off it connects automatically everytime once you start Tom Tom again.
Dean
Rmac
PostPosted: Sat Sep 18, 2004 5:11 pm    Post subject: TT3 and 2210 Reply with quote
I have now completed 1000 ml trip with GPS system (2210 & Tom Tom BT Receiver) - very impressed with results - took us to all destinations without fail sometimes navigating on all day trips - no BT drop outs at all - problems encountered to date are:
Have to set up BT port every time in use to get GPS to communicate
TT3 sometimes hangs after setting up a route and switching from map to navigate - it starts recalculating route again and invariably hangs in this loop - have to soft reset to restart
Ralph Mackenzie
rog20VT
PostPosted: Tue Sep 21, 2004 8:44 pm    Post subject: Reply with quote
i have found on occasions that TT3 seems to be running many times in the background. to check this, in the PPC settings menu go to memory, then system and clear the 'running programs' box.
then after TT3 use, choose the 'exit application' option from the TT3 menu. works for, me and picks up the GPS instantly.
22.064 (26 Jun 24)
