Pocket GPS World :: View topic - Fortuna Clip-on - getting ST mode back after flashing?
MarkH
PostPosted: Fri Aug 20, 2004 3:35 pm    Post subject: Fortuna Clip-on - getting ST mode back after flashing? Reply with quote
I knew I was meant to change the mode before flashing but I changed it to the wrong mode. It didn't help that the first page of the PDF instructions keep disappearing because it requires Chinese language installation.
Has anybody a flash image for flashing the ST chip back to the way is was. I can't seem to get a fix in ST or XT mode.
czachari
PostPosted: Sat Aug 21, 2004 7:17 pm    Post subject: You need to set the GPS in "boot mode" Reply with quote
Unfortunately, no one has been kind enough to shed some light into how to accomplish that, not even fortuna tech support.
CZ
MarkH
PostPosted: Sun Aug 22, 2004 5:31 pm    Post subject: Reply with quote
My device still works but I'm getting quite a bit of lag - it's around 50m behind when I'm walking in both ST and XT modes.
MarkH
PostPosted: Mon Aug 23, 2004 10:53 am    Post subject: Reply with quote
I've got an ST firmware off Fortuna this morning. I've put it on my server:
http://www.markhorgan.com/store/STfirmware.zip
Put the device in ST mode before you flash the ST firmware and follow the same procedure as flashing the XT firmware. I've just flashed mine ok, I will try out the receiver sometime later to see if it works any better.
MarkH
PostPosted: Mon Aug 23, 2004 7:49 pm    Post subject: Reply with quote
ST mode seems to work again. Tried XT mode, the first time I was getting lots of lag and 'sticking' but the second time it seemed to work ok. At least my receiver is usable again. Smile
jlw
PostPosted: Tue Aug 24, 2004 4:13 pm    Post subject: Reply with quote
where do i downloadthe flash software again?
Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case
MarkH
PostPosted: Tue Aug 24, 2004 10:53 pm    Post subject: Reply with quote
http://www.fortuna.com.tw/download/
ClipOnSyncBT.zip
Clip-OnSync.pdf
22.062 (12 Jun 24)
