Pocket GPS World :: View topic - VW 2011 Volkswagen Passat Sport sat nav
Kirium
PostPosted: Wed Mar 09, 2011 9:16 pm    Post subject: VW 2011 Volkswagen Passat Sport sat nav Reply with quote
Hi, I have a VW Passat Sport on order, it's arriving in approx 5 weeks. It's comes with the rns315 sat nav fitted, my question is can I put personal poi's on ? Namely speed cams ?
Any advice gratefully received, Matt
Apple iPhone 5, Navigon, Brodit ProClip Mount
miktdish
PostPosted: Tue Nov 01, 2011 3:46 pm    Post subject: Re: VW 2011 Volkswagen Passat Sport sat nav Reply with quote
Hi - how did you get on with this ?
I too have a VW passat with the RNS315.
AndyVaughan
PostPosted: Tue Nov 01, 2011 9:35 pm    Post subject: Reply with quote
You can add them to a RNS 510, so I don't see why not.
It is a bit more involved than just copying some files though.
Best port of call is probably the vwnavi.com forums for specialist advice.
miktdish
PostPosted: Wed Nov 02, 2011 2:50 pm    Post subject: Reply with quote
Cheers - i've had a quick look, info seems to be a bit lacking for the DNS-310 though Sad
AndyVaughan
PostPosted: Thu Nov 03, 2011 9:18 pm    Post subject: Reply with quote
Have you tried the same method as for the RNS-510 and using POInspect0r and putting them on SD Card?
Kirium
PostPosted: Fri Nov 04, 2011 3:19 am    Post subject: Reply with quote
Hi, The short answer is no....
Depending on which software version you get you can't even navigate to a 7 digit postcode let alone put custom poi's on... I'm assuming the cars new so you'll probably have the lastest software (W031), in which case you will be able to use 7 Digit postcodes.
An interesting thread:
http://www.vwaudiforum.co.uk/forum/showthread.php?124199-RNS315-StNav-and-7-digit-postcodes
I still use my iPhone Navigon software and CamerAlert to take me to where I'm going and the RNS315 and CamerAlert to get me back... Glad I didn't pay for the VW unit.
AndyVaughan
PostPosted: Sat Nov 05, 2011 6:12 pm    Post subject: Reply with quote
Is this the same unit as the Skoda Amundsen?
If so, new software and maps have just been released on SD card. It appears the SD Cards are encrypted and are a one time use only.
I can't find anything anywhere about importing POIs for these though Crying or Very sad
23.053 (21 May 25)
