Pocket GPS World :: View topic - Nuvi 1440 Users - Help Please - Subscribers
PostPosted: Thu Nov 03, 2011 2:15 pm    Post subject: Nuvi 1440 Users - Help Please - Subscribers Reply with quote
Can any Nuvi 1440 users assist or comment on this post?
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=569862#569862
Any subscribers having a similar issue or advice?
PostPosted: Thu Nov 03, 2011 7:09 pm    Post subject: Reply with quote
If I could read the topic I might be able to help, but apparently I need special access:
PostPosted: Thu Nov 03, 2011 7:12 pm    Post subject: Reply with quote
It's related to installing our database so is in the subscriber only section.
Delndi wrote:
I have just subscribed and downloaded the latest database and have a couple of problems.
1. It has corrupted about 20 of my favourites renaming them with numbers such as 84.25, 85.69, 87.14 and declassifying them from the category they were in such as "customer" or "hotel" and displaying them as "favouites". I then have to go through each one reclassifying them
2. I can only get the Garmin "bong " sound and not voice alerts
3. It is alerting on every camera on both sides of the road and not just the ones on my side
4. Since downloading the database the Nuvi has frozen twice - both times just before motorway exits causing a 6 or 7 mile detour. The Nuvi has never frozen before
And my reply:
Our database could not be responsible for the corruption of existing favourites on your device. Our data is simply a record of locations, in the Garmin approve format, and uploaded and installed by Garmin's POILoader Software.
Have you downloaded and installed one of our voice packs? And if so, have you downloaded the correct version? Some Garmin's support .wav voice files, other .mp3, and you must install the correct type.
Garmin have no facility to warn for cameras on one side or the other. They reserve this for their own service only.
We have had no other reports of issues from Garmin users and we have many so I'm at a loss as to what to suggest. What version of POILoader are you using?
PostPosted: Thu Nov 03, 2011 9:19 pm    Post subject: Reply with quote
I can partly answer it. The renaming of favourites like that is well documented and previous example have occurred after a software update. There are 2 options to solve it.
Either rename/edit them all individually or reload the previous GPX file, if you have a copy.
willton
PostPosted: Fri Nov 04, 2011 8:48 am    Post subject: Reply with quote
bong instead of voice alerts prob caused by
1. not having same named wav files in POILoad folder
or
2. not having the SOX file in the same folder as the files before running POILoader
willton
PostPosted: Fri Nov 04, 2011 8:51 am    Post subject: Reply with quote
alerting both sides of road? Is it a directional set?
Maybe the database has been installed twice (easy to do ive done it) usually by giving different name to POI file in POILoader. Easy to check in Where To; Extras; Custom POIs and check listings
PostPosted: Fri Nov 04, 2011 10:19 am    Post subject: Reply with quote
Darren's answer at post three explains this. It's a Garmin problem.
dales
PostPosted: Fri Nov 04, 2011 12:21 pm    Post subject: Reply with quote
NB sox.exe belongs in the same folder as PoiLoader.exe
Dales
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
22.094 (25 Sep 24)
