Pocket GPS World :: View topic - Kenwood DNX-5280
Kenwood DNX-5280
Petershil
PostPosted: Mon Oct 31, 2011 10:59 am    Post subject: Kenwood DNX-5280 Reply with quote
I have the Kenwood DNX-5280 and I cannot load POIs to it.
I haver the 5220 so am familiar with the usual hassles, but this is worse.
If I put the SD card in it just says "reading", and goes no further.
The same if I try and do it via USB.
If I delete the file from the card then it can read, play MP3s, display images and go through the directory as usual, but as soon as you load poi.gpi, ot poi.poi onto it the it just sticks.
Has anyone managed to load POI onto a 5280?
PostPosted: Mon Oct 31, 2011 11:57 am    Post subject: Reply with quote
Why do Kenwood have to make this so damn difficult? It seems that with every model there is a different issue and, given it's supposed to be running Garmin software, it should be a simple process.
On the other hand, are you using POILoader and if so, what version? I ask as the latest version has caused Garmin users a number of issues and wonder if yours may be related?
The previous stable version of POILoader, 2.61 seems to be problem free and we have it here if you want to give it a whirl.
baltinemrac
PostPosted: Tue Dec 06, 2011 9:42 pm    Post subject: I have the same problem Reply with quote
I have the same problem.
I have tried with older poi loader versions.
I have tried with other file and folder names.
I have tried with sd card and usb.
It always stays in reading... and go no further.
Any help?
PostPosted: Tue Dec 06, 2011 10:02 pm    Post subject: Reply with quote
As Peter never replied, can you tell me what version of POI Loader you are using?
Petershil
PostPosted: Sat Oct 06, 2012 10:45 am    Post subject: Reply with quote
OK, an update on this that might help fellow users.
I spent a lot of time talking to Kenwood and the upshot of it was that you couldnt do it.
There has now been a new firmware release and you can now do it.
You have to have a USB stick with a file called garmin, and the poi file in that folder.
You insert the USB when the navigation is showing the "where to or view map" screen.
It will then update.
Finally! Nightmare over!
PostPosted: Sat Oct 06, 2012 10:47 am    Post subject: Reply with quote
Thanks Peter for updating us. Kenwood seem hell bent on making this far more complex than it needs be!
22.064 (26 Jun 24)
