Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Fri Oct 21, 2011 9:58 pm Post subject: |
Andy_P wrote: | Auto-switch on is good isn't it? But if it's anything like the version I've seen, they still need to do some work on the wording of the menus to select it. |
With 9.061 I can't find any option to deselect auto-switch on? _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Andy_P Pocket GPS Moderator
Posted: Fri Oct 21, 2011 10:49 pm Post subject: |
See Ian's post above... It looks like they've combined it with the 'auto-off' selection option now. _________________ "Settling in nicely" ;-) |
Posted: Sat Oct 22, 2011 10:21 am Post subject: |
If you select auto-off in Battery Saving Preferences, that setting is lost every time the device reboots eg on disconnecting from Home. But it still has auto-on, so seems no way of changing it? _________________ Mike R [aka Wyvern46]
IanS100 Frequent Visitor
Posted: Sat Oct 22, 2011 12:53 pm Post subject: |
Guivre46 wrote: | If you select auto-off in Battery Saving Preferences, that setting is lost every time the device reboots eg on disconnecting from Home. But it still has auto-on, so seems no way of changing it? |
I've just checked this & as far as the settings go my 550 is the same, the setting is lost when disconnecting from home but it never the less continues to switch on & off with power connect / disconnect ie
Disconnect from home - disconnect from power 550 goes off
Power connect - 550 on
Power disconnect - 550 off etc etc
On checking the Power Saving setting the box is ticked but the 550 ignores it.
Untick the box & then tick it again & it then seems to function correctly as per the setting. I think the reboot screws up that command & it appears to be ticked when in fact it is not  _________________ Galaxy Note 4 / TomTom GO : CamerAlert : CoPilot |
Posted: Sat Nov 05, 2011 8:39 pm Post subject: |
Also found that the update scrambled third party POI icons and titles eg the National trust icon was captioned 'Kia Dealers England and Wales'. Removed the POIs and reloaded - fine now.
Edit: Should have said I noticed this in the 'Warn when near POI' section. _________________ Mike R [aka Wyvern46]
JimmyTheHand Frequent Visitor
Posted: Sun Nov 06, 2011 12:22 pm Post subject: Re-booting |
My 550 doesn't seem to have rebooted since upgrade - has TomTom fixed it or am I had a lucky week? _________________ J. |
Posted: Sun Nov 06, 2011 12:33 pm Post subject: Re: Re-booting |
JimmyTheHand wrote: | My 550 doesn't seem to have rebooted since upgrade - has TomTom fixed it or am I had a lucky week? |
Don't fret it'll be back to normal with the next update & maybe with a few extra reboots to compensate  |
Posted: Sun Nov 06, 2011 1:25 pm Post subject: Re: Re-booting |
IanS100 wrote: | JimmyTheHand wrote: | My 550 doesn't seem to have rebooted since upgrade - has TomTom fixed it or am I had a lucky week? |
Of course that requires me to connect it to TomTom Home - which only happened because I had a full backup _________________ J. |
Posted: Sun Nov 06, 2011 4:38 pm Post subject: |
I've had a couple of reboots, both times seemed linked to problem with connecting to Live services. Have also had to reboot once when voice guidance ceased to work. _________________ Mike R [aka Wyvern46]
Posted: Sun Nov 06, 2011 9:10 pm Post subject: |
Guivre46 wrote: | I've had a couple of reboots, both times seemed linked to problem with connecting to Live services. |
it always seemed related to Live Services in ver 9.58 and I am sure it seemed to change how often when they altered the range of the Traffic (I wonder whether it was bad packets from server caused the process to crash) _________________ J. |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Mon Nov 07, 2011 10:35 am Post subject: |
only just updated ...is it me or is the button pushing a little quicker ie getting to poi location to enter a poi _________________ TomTom 5001 |
DaveNN Lifetime Member
Posted: Mon Nov 14, 2011 2:22 pm Post subject: |
Guivre46 wrote: | I've had a couple of reboots, both times seemed linked to problem with connecting to Live services. Have also had to reboot once when voice guidance ceased to work. |
ditto...
More worrylingly for me is that the TT now simply freezes for no apparent reason.
I've also noticed that it does appear to take a bit longer to get a GPS signal.
Still...it boots up on ignition now..which is nice!  _________________ Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge |
psyskiesman Lifetime Member
Joined: Jun 22, 2004 Posts: 322 Location: Swindon, Wiltshire
Posted: Mon Nov 14, 2011 6:18 pm Post subject: |
DaveNN, I had that problem as well. Ran clearflash tool 3 times and all seems to be OK now. |
Posted: Tue Nov 15, 2011 8:36 pm Post subject: Re: Re-booting |
Answer is lucky week - had a couple of reboots now  _________________ J. |
Posted: Sat Nov 19, 2011 12:54 pm Post subject: |
The auto-on function seems independent of the battery saving option for 'shut down when disconnected from power'. I suspect that the device may shut down after a certain period of inactivity - I just haven't wanted to hang around to see it actually happen? _________________ Mike R [aka Wyvern46]
