Pocket GPS World :: View topic - Precautionary battery change for 940?
hijacker
PostPosted: Mon Oct 17, 2011 9:02 am    Post subject: Precautionary battery change for 940? Reply with quote
My 940 is now 3 years old and uses the original battery. It's still capable of holding a charge but given I would like to continue using this for as long as possible would it be a sensible move to replace the battery in the event that battery leakage occurs onto the PCB and prematurely breaks my 940?
I've seen the YOUTUBE clips for replacement and I'm quite happy to do this myself.
Any recommendations for a quality replacement battery?
TT GO 1005
PostPosted: Mon Oct 17, 2011 9:31 am    Post subject: Reply with quote
My take on this FWIW is that if the battery still holds its charge, then leave it alone. Others may have a different opinion.
People have broken their TTs whilst trying to change the battery. Sad The last comment was not meant as casting aspersions about your battery changing abilities. Very Happy
PostPosted: Mon Oct 17, 2011 10:30 am    Post subject: Reply with quote
I'm in agreement with M8TJT. If it ain't broke, leave well alone.
PostPosted: Mon Oct 17, 2011 10:49 am    Post subject: Reply with quote
I would leave it alone for the time being its rare to see a battery inside a TomTom that has sprung a leak.
The Live products all use a battery with a five pin connector these are very difficult to source, usually you cut the lead off the old battery and solder it to the new one.
Removal of the battery in the x40/ x50 is actually easier than the earlier devices as its attached to the rear case rather than being glued to the PCB, but its still quite a teardown to get at it - Mike
22.094 (25 Sep 24)
