Pocket GPS World :: View topic - SpeedCams need updating for Sygic
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
Eugene7
PostPosted: Fri Oct 07, 2011 4:07 pm    Post subject: SpeedCams need updating for Sygic Reply with quote
The .bmp images with the Sygic Speedcam downloads for Sygic need to be changed - Sygic uses square 100x100 images, either 8 bit or 32 bit bmp format.
Also, the UK Consolidated SpeedCam data loads ok into Sygic (after using the Sygic POI Converter), but the Europe SpeedCam data causes a load failure error in Sygic.
Any ideas why this error is happening?
Cheers.
PostPosted: Fri Oct 07, 2011 4:14 pm    Post subject: Reply with quote
the current images work fine for me. where do you get the 100x100 size from? that seems pretty large!
does the upi / rupi convertor give any error with the europe cams? any line number or anything like that?
Eugene7
PostPosted: Fri Oct 07, 2011 10:07 pm    Post subject: Reply with quote
The POI size of 100x100 is from the Sygic website.
There are no poi conversion errors with conversion software - the problem is when trying to install them...
Guess this could mean a Sygic error?
Eugene7
PostPosted: Sat Oct 08, 2011 11:46 am    Post subject: Reply with quote
The error on importing Europe Speed Cams seems to be that with Sygic you can only import POIs for maps you have active...
So, as I have UK, France and Italy only I can't use the Pocket GPS Speed Cams for Europe, as they need maps within Europe I don't have!
Sad
We need the Europe Speed Cam data base to be split into separate countries.
Eugene7
PostPosted: Mon Oct 10, 2011 5:12 pm    Post subject: Reply with quote
Can we get the EUR SpeedCam data broken down into Countries for Sygic???
PostPosted: Mon Oct 10, 2011 11:49 pm    Post subject: Reply with quote
At the moment, no... Sorry...
peterc10
PostPosted: Tue Oct 11, 2011 9:50 pm    Post subject: Reply with quote
Not even if we are really nice and say pretty please?
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
Pocketgps
PostPosted: Thu Oct 13, 2011 7:19 pm    Post subject: Reply with quote
What it says on Sygic:
The icon (.bmp file) should be in square format e.g. 100x100px. If the icon is too big or too small, it will be adjusted automatically by the app.
The icon should be either 8 bit or 32 bit bmp format
peterc10
PostPosted: Thu Oct 13, 2011 7:55 pm    Post subject: Reply with quote
The bit about the software adjusting it automatically is wrong, to a certain extent.
These icons are used in two ways by Sygic. First they show on the map in the position of the camera, but that is always small and that does not change with file size. The second way is that they also appear in a separate pop up box with a count down of the number of yards away they are. It is this part that does not work automatically - the size of the icons depends upon the size of the file and is too small for what I am using (some 44 x44 ones I found).
I think the pop up box is a very good feature if only I could get the icon to fill its box.
Peter
HTC Sensation
Copilot for USA
Eugene7
PostPosted: Sat Oct 22, 2011 4:38 pm    Post subject: Reply with quote
MaFt, what are the countries covered in the Euro SpeedCam Database?
I will need to get all the countries for now to enable the database to install.
Also, I have found 88 x 88 px icons to be the best seize overall for Sygic.
peterc10
PostPosted: Sat Oct 22, 2011 8:02 pm    Post subject: Reply with quote
You can find the info by clicking on "download speed cameras" then clicking on "Click here to see a full breakdown of both UK and International cameras in the current database".
Peter
HTC Sensation
Copilot for USA
wrinklyninja
PostPosted: Wed Jul 25, 2012 3:04 pm    Post subject: Sygic/Aura Europe Reply with quote
I agree with previous post. Sygic will not accept a Europe wide database. Only individual countries. UK works a treat but can't get any cameras installed for Spain. I guess that's a pain in Spain (groan).
Might have to start saving for the TomTom Android app. (if and when it ever arrives) unless the wizards here can sort a fix.
PostPosted: Wed Jul 25, 2012 4:53 pm    Post subject: Reply with quote
Hmm - will have to look into that. Not sure there'll be any easy way to do it :/
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
23.021 (05 Feb 25)
