struttob Occasional Visitor
Posted: Tue Sep 20, 2011 11:37 pm Post subject: adding POI's |
I have downloaded some POI's and they are on my PC as zipped files - how do I get them onto my Garmin 1490T ? |
Andy_P Pocket GPS Moderator
Posted: Wed Sep 21, 2011 7:51 pm Post subject: |
To unzip the files, you can just right-click on the zip-file and select "Extract all". Follow the instructions and it will create a new folder with all the individual files inside.
To upload them onto your Garmin, you use the POILoader program, just as you did to add the Speed Camera Database files (so you can use the same instructions here: Installation Guide.
POILoader always used to wipe out all the existing POI files when you loaded any new ones, so the easiest way was to keep a folder on your PC where you collect all the speed camera and other POIs, then upload them all in one go with POILoader.
Apparently the latest versions of POILoader are a bit cleverer now, but it still seems the simplest way to keep everything organised.
Maybe someone with more Garmin experience will add to this with some more detail. _________________ "Settling in nicely" ;-) |
willton Lifetime Member
Posted: Thu Sep 22, 2011 6:24 pm Post subject: |
ive just installed PGPSW cams onto my new 3760. It will now let you install POIs with a different name, so you can add POIs without losing your existing ones.
But installing (updating) and existing set will overwrite all of that set.
Having got the little devils to show on the map, I am infuriated by how small the icons are !! You cant see them unless you zoom right into the map - you wont be able to see them driving along.
Im going to spend another 4 hours browsing the forums to see what others have done about this. |
Kremmen Pocket GPS Verifier
Posted: Fri Sep 23, 2011 6:37 am Post subject: |
I think You've probably done something wrong because the icons on mine are perfectly visible.
1) Are you using the 22x22 .BMP's ?
2) Are they in the same folder as the CSV/GPX files ?
3) Do they have the same filename prefix as the CSV/GPX files ? _________________ Satnav:
Car Average MPG :
Posted: Fri Sep 23, 2011 11:33 am Post subject: |
yeah the icons are set up properly - i used the ones that come with the PGPSW speedcam download for poiloader.
I expect the issue is that they will pop up en route, but if you are simply browsing the map they wont show unless you are 2 points from max zoom.
the reason i bought this 3760 is cos the icons dont show so well on CoPilot 9 android.
Will the 24x24 BMPs make any difference ? |
Posted: Wed Oct 05, 2011 6:50 pm Post subject: help please help |
well i thought they might pop up on route, but on either view setting while navigating i get the warning then i can just see a tiny icon (the same size as all other POI icons) on the road.
My issue is that it is not easy to see and requires some distraction from the road ahead to find it.
This is not what I am used to on my old system (Destinator - dont laugh) - how can i make these icons bigger or more visible.
I am tearing my hair out now with these programs - thats this, ALK CP9 Premium app, and Navigon app ive wasted my time and money with now. |
Posted: Wed Oct 05, 2011 6:53 pm Post subject: |
i am sure i saw a vid (youtube?) of someone showing the speedcams on a section of UK motorway using a garmin ..... now if only i could find it again
Edit: yes its at the top of this BB !!
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Wed Oct 05, 2011 7:27 pm Post subject: |
For my nuvi, I resized all the icons to 24 x 24.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Wed Oct 05, 2011 8:01 pm Post subject: |
cheers Dales - ive used the 24x24 ones, but doesnt the nuvi resize them to a standard size for POI display? it doesnt seem to make any difference on the screen. |
Posted: Fri Oct 07, 2011 12:54 pm Post subject: |
On my nuvi, the 24x24 icons do appear bigger than the 22x22 ones.
And they certainly appear very much bigger than the ones showing in your screenshot on your other post.
Posted: Fri Oct 07, 2011 3:09 pm Post subject: |
Thanks dales - what model nuvi is yours ? |
Posted: Fri Oct 07, 2011 3:24 pm Post subject: |
It's a nuvi 255WT.
Posted: Fri Oct 07, 2011 3:26 pm Post subject: |
kremmen said the same - his is a 2200 |
Posted: Fri Oct 07, 2011 3:30 pm Post subject: |
other post is here for anyone wanting to see pic at top of thread |
