Pocket GPS World :: View topic - PGPSW Speed Camera Database on TomTom iPhone App
Goto page Previous  1, 2, 3 ... 25, 26, 27 ... 40, 41, 42  Next
adobbing
PostPosted: Fri Sep 30, 2011 9:34 am    Post subject: Reply with quote
rogercul wrote:
I just somehow need to set up a Europe MapSettings.cfg files. I am having real problems doing this on my 730.
I don't suppose there is anyone out there who is willing to share one with me Very Happy
Thanks for all your help,
Roger
I have a mapsettings.cfg file with warnings for all the UK and also European PGPSW cameras in.
It is set to warn at 700 yards using bell 1 for fixed cameras and beep 5 for mobiles, it was created on an SD card copy of my old GO 740 live.
Although with spoken alert OGG files installed, the sounds are overridden with the spoken alerts.
Would this be of use?
If so, somebody let me know how to add to the forum?
rogercul
PostPosted: Fri Sep 30, 2011 9:54 am    Post subject: Reply with quote
That would be great!
Would you mind emailing it to me?
Roger
adobbing
PostPosted: Fri Sep 30, 2011 9:56 am    Post subject: Reply with quote
Roger
Pm me your email address
rogercul
PostPosted: Fri Sep 30, 2011 11:22 am    Post subject: Reply with quote
Roger
Thank you very much for your help. It (almost) works a treat now.
The only slight issue I still have is as follows:
I converted the European zoned bmp files using FastStone (an excellent program).
1) I changed the file type to PNG
2) I selected 24-bit (with max compression and no filter)
3) I resized to 96 x 96 (pixels) and left 'preserve aspect ration' ticked
4) Copied them across to the western europe folder.
Now they show up fine in the POI menu, but on the actual map, they just show up as red squares???
It seems i just can't manage to re-format/rename the bmp files.
Sorry to be a pain,
Roger
adobbing
PostPosted: Fri Sep 30, 2011 12:42 pm    Post subject: Reply with quote
Roger
Is it not 44 x 44 ?
Mine are all 44 x 44 including some I initially made myself for 740 live and then converted to PNG format for iPhone.
They all seem to work OK on the iPhone 4.
adobbing
PostPosted: Tue Oct 04, 2011 8:12 pm    Post subject: Reply with quote
adobbing wrote:
Roger
Is it not 44 x 44 ?
Did 44 x 44 work?
PostPosted: Tue Oct 04, 2011 9:24 pm    Post subject: Reply with quote
It is general forum etiquette not to quote the post that you are answering if your answer is immediately below that post. It just takes up uneccesary space Confused . Use the Reply button at the bottom, rather than the Quote button Very Happy See above post. 8 blank lines and about 6 rows of text for a 1 line about 15 character answer
PostPosted: Fri Oct 07, 2011 3:21 pm    Post subject: Reply with quote
iPhone 3G/ 3GS = 22x22
iPhone4 =44x44 (Note it will work with 22x22 but they look very small on the screen) - Mike
adobbing
PostPosted: Fri Oct 07, 2011 4:03 pm    Post subject: Reply with quote
Apologies, but I have better things to do than count blank lines!
rogercul
PostPosted: Sat Oct 15, 2011 4:18 pm    Post subject: Reply with quote
I finally go around to playing with TomTom again (after IOS5 reset it and removed my mapsettings.cfg file, thus removing all speed cameras).
I re-converted the BMPs using FastStone (thanks again for the tip) to 44x44 PNGs, and it all works fine now, even in Europe! The only problem now is that the pgps Euorpean database seems very limited Crying or Very sad
I will have to make a note of all cameras I pass on my next trip and submit them to enhance the data base a bit Very Happy
Thanks for all your help on this one, and most especially for the mapsettings file.
PostPosted: Sat Oct 15, 2011 5:42 pm    Post subject: Reply with quote
You also stand a much better chance of becoming one of the 'Lifers' by submitting foreign cams. Very Happy But get them accurate Shocked
vibeone
PostPosted: Fri Oct 21, 2011 9:49 pm    Post subject: Reply with quote
Hey guys,
Firstly 1.9 seems compatible with 1.7 files, and with my old files from before ios5.
Also, does anyone have a complete set of PNG's/BMP's + X2's for iPhone 4 (Retina 44x44?). I'm struggling to fix. I have all icons, but only small.
A zip would be MUCH appreciated!
PostPosted: Sat Oct 22, 2011 9:08 am    Post subject: Reply with quote
There is a download on page one of this thread that contains iPhone4 icons at 44x44 - Mike
PostPosted: Sat Oct 22, 2011 10:02 am    Post subject: Reply with quote
But it's not immediately obvious that it contains the 44x44 icons Mike Very Happy
st1967
PostPosted: Sat Oct 22, 2011 2:34 pm    Post subject: Reply with quote
Thanks guys,
As I was messing about with my POIs with the 1.9 update I figured I might as well go the whole hog and integrate the speed cameras rather than use the app. Figured there would not be another update for a while now, I hope TomTom got it right 1st time Laughing Out Loud
Samsung S22 Android, Google Maps & Camera Alert
Page 26 of 42
