Pocket GPS World :: View topic - CoPilot5 Speech Software Problem!
typhoon29
PostPosted: Sat Aug 21, 2004 12:40 pm    Post subject: CoPilot5 Speech Software Problem! Reply with quote
CoPilot Live Pocket PC5 - Software Only
Hi I've just recieived my software.. but having afew having a problems.
1) I've followed all the instructions but can only get the Male TTS voice
2) When I open Copilot on my PC it comes up with an error message, I've uninstalled re installed several time but the problem persists.
The Error message reads -
COPILOT caused an exception 03H in module <unknown> at 0000:00000033.
Registers:
EAX=050301bc CS=0167 EIP=00000033 EFLGS=00000246
EBX=051407f0 SS=016f ESP=07beff74 EBP=051407f4
ECX=051407f4 DS=016f ESI=051407f0 FS=13cf
EDX=81891980 ES=016f EDI=00000000 GS=0000
Bytes at CS:EIP:
09 82 00 cc 09 9a 00 cc 09 65 04 70 00 07 00 70
Stack dump:
00000000 00aa1c4f 051407f0 bff92d08 00003a98 00aa2124 818bf018 00000008 07beffcc 81891920 bff88f20 051407f0 818bf018 00000008 81891920 00000007
Any help would very much be appreciated,
Thank you.
kartracer
PostPosted: Sat Aug 21, 2004 2:57 pm    Post subject: Reply with quote
1) In order to switch from the male TTS voice to the female WAV voice you have to deinstall Pocket Speech from the Pocket PC and then reinstall using the other option. You only get these 2 options with the UK English version.
2) I've not come across this particular error, but I was also finding the desktop component rather unreliable. I was getting errors which forced the program to close. I could then only get it to work again after restarting the PC. I have just installed XP Service Pack 2, and (fingers crossed) it seems to behave better now.
Kam
PostPosted: Sat Aug 21, 2004 4:05 pm    Post subject: Reply with quote
Which Pocket PC are you using ?
Also try soft resetting the Pocket PC before running and also run up START | SETTINGS | MEMORY and see how much PROGRAM MEMORY (right hand slide of slider) you have available.
Aim for around 12-15mb, anything lower and you may get memory errors when starting CoPilot.
typhoon29
PostPosted: Sat Aug 21, 2004 10:49 pm    Post subject: Reply with quote
Thank you very much for your advice I've now got the voice sorted.
Cheers :D
22.062 (12 Jun 24)
