Pocket GPS World :: View topic - A new one on me....
A new one on me....
FrequentFlyer
PostPosted: Thu Sep 29, 2011 5:31 pm    Post subject: A new one on me.... Reply with quote
Any ideas why an Active device running 1.5 can zoom in OK, but on the map concerned cannot 'see' the 1:25 scale., only 1:50...is it really likely to be a fault with the map itself...if so , I guess that must be a first ?
LostMike
PostPosted: Thu Sep 29, 2011 6:36 pm    Post subject: Reply with quote
Dumb question but - has it got the 1:25000 scale or is it just a 1:50000 map?
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
RavingDave
PostPosted: Fri Sep 30, 2011 2:41 pm    Post subject: Reply with quote
This happens to me also occasionally. Try toggling through the maps to get to the 25k scale map, rather than zooming in - this should bring the 25k map back, and then zoom in/out should work as expected. Seems to be a glitch in toggleable maps which for some reason 'forgets' about one of the available scales. I've not found a repeatable way of demonstrating this glitch so have not reported to Satmap - I just know it happens from time to time!
lostme
PostPosted: Sat Oct 01, 2011 7:00 pm    Post subject: Reply with quote
I am having exactly the same problem and I am getting it every time. My toggle button has broken off, need to send it back to Satmap. Anyone any suggestions for how I can dispay both 1:50,000 and 1:25,000 in these circumstances.
RavingDave
PostPosted: Sun Oct 02, 2011 12:05 am    Post subject: Reply with quote
If your left hand side bottom button is still working, then while in Map mode you can press the joystick button, then select 'Map Packs'. This should display your available maps, and you should be able to scroll through each available map using the joystick left/right, then press 'view map' button (or press the joystick button).
23.054 (28 May 25)
