dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Wed Aug 31, 2011 5:39 pm Post subject: Beware PoiLoader 2.7 |
PoiLoader 2.7 just announced itself, so I installed it.
But it created a .poi file (not a .gpi file) so the satnav didn't recognise it.
And Ash10 didn't recognise it either - the icon kept flashing that updates are available (even though they had been installed).
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
PhilHornby Frequent Visitor
![](http://phil.hornby.me.uk/images/FaceBookVVsmall.jpg)
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Wed Aug 31, 2011 6:17 pm Post subject: Re: Beware PoiLoader 2.7 |
dales wrote: | And Ash10 didn't recognise it either - the icon kept flashing that updates are available (even though they had been installed). |
That's probably because they changed the executable's file name from
"POILoader.exe" to "POI Loader.exe" ... for reasons best known to themselves...
(... it broke my batch file too )
Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Thu Sep 01, 2011 11:39 am Post subject: some of it... |
Kremmen wrote: | I posted this last Friday: |
You didn't mention the change of executable name though
Posted: Thu Sep 01, 2011 12:36 pm Post subject: |
As soon I saw they had 'goofed' (again) I stopped reading and made a mental note to stick my current POI Loader. _________________ Satnav:
Car Average MPG :
willton Lifetime Member
Posted: Fri Sep 23, 2011 11:45 am Post subject: |
ive used the new POI loader and experienced this, but if you choose to save the files to your computer instead of device it will create the .gpi file.
My next trick is to see if i can fool it by saving it to my computer, and then selecting the microsd drive and it should save it as .gpi then when i disconnect and start device it will install em. ill let you know when ive done it.
Also you can load different POIs using a different name and it wont wipe out existing ones on the device (of a different name) OR you can update your PGPSW cams file (overwrite) without deleting all your other POIs (as long as they have different file name) afaik |
Posted: Mon Sep 26, 2011 5:17 pm Post subject: works fine |
if you chose the sdcard as a drive on your computer and elect to save the files there you get a .gpi file, which will offer to install itself after you have properly disconnected from your PC and switched the garmin on. No need to save the file and THEN copy it over to your sdcard. |
Darren Frequent Visitor
Posted: Tue Sep 27, 2011 9:30 pm Post subject: |
Darren wrote: | Also, is there a repository for older POILoader versions available anywhere? |
Yes, they're HERE |
Posted: Tue Sep 27, 2011 9:31 pm Post subject: |
Cheers Phil. _________________ Darren Griffin |
