Solly Occasional Visitor
![](modules/Forums/images/avatars/gallery/simpsons10.jpg)
Posted: Fri Aug 20, 2004 10:55 pm Post subject: How to add new POI that I come across |
First I need to say a massive thank you to all members who contribute here. I have just bought myself a MEDION and its been a pleasure. However, I have one small problem - How to add new POI that I come across? , I see there is an option to use some hardware key but I still cant do it. Any assistance would help
Thanks |
rd57chad Occasional Visitor
Posted: Sat Aug 21, 2004 5:27 pm Post subject: |
You have to assign a key on the pda . Start POI warner up & then select one off the options from the bottom left of the screen . Cant remember which 1 but theres only 4-5 to chose from anyway . |
Posted: Sat Aug 21, 2004 8:48 pm Post subject: |
I cant locate these options on the bottom left of the screen as you have suggested. Am I overlooking something. There are 4 keys on the PDA - Key 1 = Home/start
Key 2 = Inbox
Key 3 = Task
Key 4 = Recorder
I changed Key 1 to POI warner but it only starts up the programme. |
fergus Occasional Visitor
Posted: Sun Aug 22, 2004 9:56 am Post subject: |
No, you need to open POIWarner, click on File..., Options and you will see an option for Hardware key for POI recorder
Fergus |
Posted: Sun Aug 22, 2004 9:07 pm Post subject: |
Yup thats it ! |
Posted: Sun Aug 22, 2004 10:25 pm Post subject: |
Guys thanks for that....got it all working now.
Mucho gracias!!!! |
dIdI Occasional Visitor
Posted: Tue Aug 24, 2004 7:26 am Post subject: |
In german there is a poi-integration software avaible.
With this software you can intergrate POI's in MN4
function:
make new poi files
load old poi files
edit the name of pois
edit the catorgorie of the pois
change the kordinaten of the pois
make new catorgies (with icons)
import of existing pois (.asc)
export pois as .asc files
delete pois
Erweiterung der MN|4 Standard Pois um eigene Einträge
load icons in different sizes
delete categorie's with all pois
edit the zoomfactor of ever poi.
More information (german) and download at:
http://www.pocketnavigation.de/board/tid34054-sid.htm
dIdI |
