Pocket GPS World :: View topic - post code wanting house no
chip6
PostPosted: Wed Sep 14, 2011 4:19 pm    Post subject: post code wanting house no Reply with quote
Hi had this problem since software upgrade and for me it is a big problem.
i put in postcode and am then asked to enter house no which i never have as is usually a site, the unit will chose one for you which you would assume would be close to postcode but very rarly is and on a long road can be miles away, any advice appriciated Ian
Anita
PostPosted: Wed Sep 14, 2011 4:46 pm    Post subject: Reply with quote
You may be interested to read the discussion in this two-year-old thread.
At that time TomTom didn't accept that there was a problem, but maybe things have improved with the newer devices.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Wed Sep 14, 2011 5:32 pm    Post subject: Reply with quote
Given that a PostCode can cover a street, a block or much larger area I don't see what else can be done?
Your only alternative would be to locate the correct address via the map, assuming you know it. If you don't, then how can your SatNav know where, in the coverage area of that PostCode, you want to go?
IanS100
PostPosted: Wed Sep 14, 2011 5:58 pm    Post subject: Reply with quote
I find the post code / house number combination gives very accurate results & is sldom more that a house out, it's certainly easier than kerb crawling whilst trying to scan poperties looking for non existant numbers
PostPosted: Wed Sep 14, 2011 7:03 pm    Post subject: Reply with quote
But the OP does not have a house number Sad
AliOnHols
PostPosted: Wed Sep 14, 2011 7:27 pm    Post subject: Re: post code wanting house no Reply with quote
chip6 wrote:
...postcode... which i never have as is usually a site,...... any advice appriciated Ian
Give the site a telephone call and see if they can give you any directions/landmarks/junctions etc. See if any of these are in the TomTom, if not try Google Maps or Street View if available and set the location using your TomTom's map view. Once at the site, store the location as a POI in a custom folder for use next time.
Garmin Nuvi 2599
SatMap Active 10 & 20.
chip6
PostPosted: Wed Sep 14, 2011 7:51 pm    Post subject: navigate to post code Reply with quote
Yes if i go on such as google maps the post code is near enough for me but not always able to.
The old software was spot on with the post code usually , am shortly in the market for a new truck program unit so was hoping it had been sorted by now , just have to wait and see.
one really bad example was a site on coventry rd at the side of M42 and the sat nav wanted to take me to centre of brum, l smelled a rat on that one and phoned ahead but have frequently been wrong end of street .
johnnym100
PostPosted: Fri Sep 16, 2011 7:59 am    Post subject: House number unknown Reply with quote
I tend to do one of 2 things:
1. Try to find house number / alternate point of reference from Google or Google Maps (and if necessary set TomTom to navigate to "point on map" rather than postcode)
2. If no joy from point 1 or no time, enter 999 as the house number. This usually generates an error e.g. "numbers must be between 5 - 279" and then just pick a mid-point number to get me close.
John.
PostPosted: Fri Sep 16, 2011 8:11 am    Post subject: Re: House number unknown Reply with quote
i like that idea, will have to remember it Smile although it wouldn't wok on Thornton Road in Bradford - it's about 8 miles long and I think the house numbers go up to about 1800!!
PostPosted: Fri Sep 16, 2011 9:13 am    Post subject: Reply with quote
But does the error message give the house numbers in the postcode or on the whole road. Surely Thornton Road has nore than 1 postcode Question
pcaouolte
PostPosted: Fri Sep 16, 2011 9:24 am    Post subject: Re: House number unknown Reply with quote
MaFt wrote:
.. I think the house numbers go up to about 1800!!
Enter 0 (zero) as the house number, this produces the same error allowing you to pick the mid point. I don't know of any properties numbered 0.
Paul
Anita
PostPosted: Fri Sep 16, 2011 10:06 am    Post subject: Reply with quote
Unfortunately it's the whole road, which can put you miles away from the required location. I couldn't make TomTom understand the difference.
Anita
UK map 1130.12368
Samsung Galaxy S21
JohnMulholland
PostPosted: Fri Sep 16, 2011 12:10 pm    Post subject: Reply with quote
Recently in St Andrews, I entered a post code and the house number; it took me to a random address about half a mile from the right one. When I entered the street name and house number, it took me to the front door of the correct house. It was not the first time the post code has let me down.
John
1005 Live
App: 12.071
Map: Europe v925.5413
PostPosted: Fri Sep 16, 2011 1:49 pm    Post subject: Re: House number unknown Reply with quote
I don't think you need to do EITHER of these.
When it asks for a house number after you've entered the postcode, just tap "Done" without entering ANY numbers.
That always seems to take me to the middle of the postcode area.
"Settling in nicely" ;-)
PostPosted: Fri Sep 16, 2011 2:00 pm    Post subject: Reply with quote
By the way... for anyone offering their experiences with ERRORS in postcodes, it's all a bit pointless unless you can state which postcode file version you're using. This is NOT necessarily the same as the map version.
To find your postcodes version number (on a model which uses Home for updates*), find the folder on the TomTom called "zip" using Windows Explorer or Mac Finder.
There will be a file in that folder called "Great_BritainPostal.ver".
Open that with any text editor (Notepad will do fine on a PC) and there will be some text such as:
Code:
[description] GreatbritainPostal_TeleAtlas 865[/quote]
....which in this case means v865 postcodes, which would have come as standard on a new device with v865 maps.
But if you have updated a map, it does not update the postcode files. You have to do it manually, so your postcodes file COULD be several versions old.
(*at present there is no way to do this on a model which uses MyTomTom).
23.012 (08 Jan 25)
