Pocket GPS World :: View topic - A Doh Query
A Doh Query
PostPosted: Fri Aug 26, 2011 10:08 pm    Post subject: Reply with quote
It's a tickbox on the "Brightness settings" page of the Settings menu, sir. Smile
"Settling in nicely" ;-)
PostPosted: Sat Aug 27, 2011 8:33 pm    Post subject: Reply with quote
Older TomToms used to have a light sensor, so they could progressively turn down the brightness in stages and switch to night colours at a sensible time, depending on the conditions (even if you're in a tunnel).
However, the new models don't, and they depend on some "look-up" tables to decide what time to switch. There's no way to edit or even look at these time-tables, so I can't see how they can be as good in all situations.
e.g. an overcast day in Glasgow is going to be darker than a bright sunny day in the channel islands.
PostPosted: Sat Aug 27, 2011 9:01 pm    Post subject: Reply with quote
The Go-x40 range were the last devices to employ an active light sensor, the Go-x50 models also had a light sensor but the day/ night switch was software controlled based upon the look up tables even though the light sensor was fitted it wasn't used.
None of the newer models have a light sensor fitted - Mike
22.063 (19 Jun 24)
