MoD Occasional Visitor
Posted: Wed Aug 18, 2004 6:16 pm Post subject: TomTom3 Bluetooth and toshiba e800 bluetooth help please |
hello people
I am at my whits end trying to get these 2 to work together.
in BT settings it says discovered and also the service name is there .
status says not connected but i have put the 0000 id thing in but i just cant get it to say connected .
any help would be appreciated please
thanks MoD |
lbendlin Pocket GPS Staff
Posted: Wed Aug 18, 2004 11:20 pm Post subject: |
you don't normally need to bond them. In the BlueTooth manager, select "connect to BlueTooth serial port" and then select the receiver from the list. Make a note of the port that it uses and specify that in the TomTom GPS applet. Set the speed to 38400 NMEA. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Aug 19, 2004 10:38 am Post subject: |
thank you for helping but .
it is useing com port 6 in the tosh bt settings and i dont have the optoin of selecting com port 6 in the tom tom gps settings .
tom tom told me to use port 4 regardles of what the pda bt settings are.
and im a noob at this sorry to say.
how do i set the speed ??? as u said in ur post .
thank you its very much appreciated
thanks MoD |
Posted: Thu Aug 19, 2004 12:51 pm Post subject: |
If you have trouble with TomTom not showing the porper port then you will need to remove the TomTom GPS driver completely (don't forget to do a soft reset before you try this) and then re-install the TomTOm GPS driver 2.07 from our downloads page.
Just to re-emphasize: You don't need to bond the devices but you MUST connect to the serial SPP of the receiver at least once from within the BT manager, otherwise it will not work. _________________ Lutz
Posted: Thu Aug 19, 2004 1:33 pm Post subject: |
serial spp ???
like i said before i am sorry for being thick at this. |
Posted: Thu Aug 19, 2004 1:45 pm Post subject: |
ok just uninstalled the tom tom gps software and soft reset then installed 2.07 as u said.
if you dont mind me asking what do i do now.
thanks |
Posted: Thu Aug 19, 2004 1:51 pm Post subject: |
go to the bluetooth manager and connect to the serial port of your BT receiver. You must see a "Connected" message or icon befiore you proceed.
then go to Start > Settings > System > GPS , on the GPS tab select NMEA 38400 and Bluetooth COM port 6 (if that doesn't work, try the other one)
Back on the first tab you should see the black dots running if all is OK. _________________ Lutz
Posted: Thu Aug 19, 2004 2:05 pm Post subject: |
ok
i can select 0183v2 3800 in the gps settings but what do i select in the next drop down box i.e
bluetooth rendering
bluetooth telephony
bluetooth card
com4
com3
usb cable
native IR
serial cable on com1
in the 1st drop down box i have NMEA 0183v2 38400 selected
cheers
p.s
i am very happy u are taking ur time to help... |
Posted: Thu Aug 19, 2004 2:09 pm Post subject: |
sorry about that i was picking the wrong thing
big thank you for putting me on the right track
:O)
cheers |
