reece34 Occasional Visitor
Joined: May 20, 2009 Posts: 15 Location: South Manchester
Posted: Tue Jun 28, 2011 8:40 pm Post subject: Rechargeable Lithuim Battery not holding a charge |
Plugged my Satmap into the USB and left it on charge overnight. It was showing it was charging so i thought in the morning it would be fully charged.
I unplugged it and tried to turn it on but its dead.
Anyone had any issues like this?? |
Posted: Tue Jun 28, 2011 9:08 pm Post subject: |
How old is the battery as they do have a life span and beyond a certain point they simply won't retain a charge, this applies to all Li-Pol type batteries - Mike |
Posted: Tue Jun 28, 2011 9:12 pm Post subject: |
less than 3 months.
its only the 2nd time ive ever tried to charge it |
rothers Regular Visitor
Posted: Tue Jun 28, 2011 10:15 pm Post subject: |
Are you charging with the mains charger or a PC USB port ? |
Posted: Tue Jun 28, 2011 10:23 pm Post subject: |
tried both |
Posted: Wed Jun 29, 2011 9:27 am Post subject: Re: Rechargeable Lithuim Battery not holding a charge |
reece34 wrote: | I unplugged it and tried to turn it on but its dead. |
When you unplug after charging the unit remains on, no need to turn it on. Was it dead immediately after charging or was it dead a few days later ? maybe you forgot to turn it off after the charge, yep I've done that
Was it really dead or just in hibernate mode. I disable hibernate, seems a daft feature to me, if you want to save power turn it off, the Satmap gets a lock quick enough from cold anyway.
My Satmap is over 2 years old and the Lipol still has enough capacity for a full 8 hours+ use after an overnight charge so maybe you have a faulty unit or battery. |
Posted: Wed Jun 29, 2011 7:04 pm Post subject: Re: Rechargeable Lithuim Battery not holding a charge |
rothers wrote: | reece34 wrote: | I unplugged it and tried to turn it on but its dead. |
As soon as i unplug it from either the mains or laptop i then try to turn it on but nothing happens.
When i use 3 AA batteries everything works fine.
Sent satmap an email last night but no reply yet.
One other thing.
I use Memory Map to plot my routes, i then convert them to GPX to use them on my Satmap. Am i better off converting them to tracks as it just said some of my routes have over 500 waypoints and it may affect the Satmap |
Posted: Thu Jun 30, 2011 1:31 pm Post subject: Re: Rechargeable Lithuim Battery not holding a charge |
reece34 wrote: | One other thing.
Same here. I rode the Llangollen Panorama Audax a few weeks using my Satmap using a route with over 2000 points and it was fine, you can safely ignore that warning although it is good practise to keep the waypoints to a minimum.
If you do want to reduce an existing route the yes convert to a track and then you can use track properties to reduce the total number of points, it will be less accurate but still probably fine to navigate by. |
