g0tch Regular Visitor
Joined: May 15, 2008 Posts: 115 Location: North Somerset
Posted: Fri Jun 17, 2011 11:02 am Post subject: |
Privateer wrote: | The v845 map is quite old, when compared to the new v870 one. However there is no reason why you shouldn't leave things alone. |
Yes, it's old but it was the last one that fitted on internal memmory. Since the later maps outgrown the internal memory, the only option is SD cards. I do have some spare 16Gb class 10 card I use for video and was wondering if they would work in the unit? Probably an overkill but just thinking out aloud. _________________ Tibor
Garmin Drivesmart 61 |
franb Banned
Posted: Fri Jun 17, 2011 3:33 pm Post subject: |
g0tch wrote: | Privateer wrote: | The v845 map is quite old, when compared to the new v870 one. However there is no reason why you shouldn't leave things alone. |
Yes, it's old but it was the last one that fitted on internal memmory. Since the later maps outgrown the internal memory, the only option is SD cards. I do have some spare 16Gb class 10 card I use for video and was wondering if they would work in the unit? Probably an overkill but just thinking out aloud. |
Not overkill at all. If it's spare anyway then use it for all/any extra maps & just leave the internal as is. |
Posted: Fri Jun 17, 2011 3:43 pm Post subject: |
It will work fine with a class 10 card, we usually recommend class 6, any higher and the device doesn't seem to go any faster but if you have a class 10 sat around spare it won't do any harm in the TomTom - Mike |
Posted: Fri Jun 17, 2011 10:14 pm Post subject: |
Many thanks for all your replies.
Regards, _________________ Tibor
greenpadman Occasional Visitor
Posted: Sat Jan 07, 2012 1:42 pm Post subject: New Map |
Hi just download a new map for my Tomtom 1005 this friday 06/01/2012
And the map number is
Map Europe V880.3808, Release date 10/2011
all the best
Norman |
