Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 64, 65, 66 ... 75, 76, 77  Next
dales
PostPosted: Wed Jun 15, 2011 3:53 pm    Post subject: Reply with quote
Hi deeranwith,
PoiLoader 2.6.1 works just fine with my wav files every week.
The only problem I encountered was, when it installed itself, it put itself into C:/Program files/Garmin (rather than C:/Garmin previously). So I had to move sox.exe to the new folder before wav files would load up.
Dales.
deeranwith
PostPosted: Wed Jun 15, 2011 4:25 pm    Post subject: Reply with quote
Thanks Dales
I had not spotted the change of location. After the install the C:\Garmin dir was still there but with only the sox.exe present!
I did have to move it to the C:|Program Files\Garmin\POI Loader dir before it worked.
Thanks for the help.
Mark Very Happy
Ash10
PostPosted: Thu Jun 16, 2011 9:54 pm    Post subject: Reply with quote
Camera Manager v3.51 beta now available
This fixes the bug with the Apply button not being enabled after changing settings on the Voice or Account tabs.
Note that any changes to the Account settings will have no effect until the next scheduled check for updates - remember that you can use Check Now from the system tray icon to force a check.
Download link below (same as before).
grayfor
PostPosted: Sun Jun 19, 2011 1:00 pm    Post subject: Reply with quote
I have tried to download the latest version using the link at the top of this subject but my ###***** browser opens a blank page instead of downloading the program.... Confused
What am I doing wrong??
BAVC10
PostPosted: Mon Jun 20, 2011 10:21 pm    Post subject: Reply with quote
Hi Ash10
I wonder is the PGPSW team have changed the settings with the latest speed camera file as I get the following error with 3.5 and 3.51 beta....
Error opening pgpsw-speed-cams-uk (or .eur).zip for reading and error opening output.csv. for reading.
Strange as 3.5 worked perferctly and I haven't changed any settings on my browser.
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
PostPosted: Tue Jun 21, 2011 10:12 am    Post subject: Reply with quote
BAVC10 wrote:
Hi Ash10
not us, haven't changed a thing.
BAVC10
PostPosted: Tue Jun 21, 2011 4:35 pm    Post subject: Reply with quote
Hmmmmmm thanks for the reply. Just wondered as I noticed one of your recent posts asked Ash if the ' workaround' could be removed.
I'll see what Ash10 comes back with
PostPosted: Tue Jun 21, 2011 7:21 pm    Post subject: Reply with quote
and he said to leave it in, so i have Smile
Ash10
PostPosted: Wed Jun 22, 2011 9:05 am    Post subject: Reply with quote
When PGPSW changed their download process, MaFt kindly put in backwards compatibility support specifically for CM - which as he said above is still there, and working as it should.
I haven't had any reports of similar problems - has anything else changed recently on your PC perhaps?
BAVC10
PostPosted: Wed Jun 22, 2011 3:46 pm    Post subject: Reply with quote
Ash10
Not that I can think of! CM3.5 worked first time but CM3.51 displays the error messages and when I went back to CM3.5 that no longer worked - hence why I wondered if PGPSW had changed anything or there was a "legacy" setting in CM 3.51 which affected previous settings. I'll completely remove all versions and edit the registry and try a "clean" install.
Thanks for the reply though.
Ash10
PostPosted: Wed Jun 22, 2011 6:32 pm    Post subject: Reply with quote
After a little head scratching, I believe that I've located the problem - it occurs when you initially add another database region and click the OK or Apply button, but after it has already made the daily check for updates.
However, it will sort itself out after the next scheduled check for updates, or you can always select Check Now... from the system tray menu.
FWIW this rather obscure behaviour affects versions 3.0, 3.5, and 3.51 alike Embarassed
Fix to follow shortly... Wink
BAVC10
PostPosted: Thu Jun 23, 2011 7:19 am    Post subject: Reply with quote
Ash10
Think you've hit the nail on the head.
I ran CM yesterday afternoon with no success, ensured I changed no settings and ran again this morning following the new PGPSW database release - SUCCESS! Very Happy
I was "testing" the 'Apply' button issue and did change regions from UK to Europe and back again during the testing so your diagnosis would seem to be correct.
Looking forward to the fix.
BAVC10
PostPosted: Thu Jun 23, 2011 7:41 am    Post subject: Reply with quote
Ash 10
I have found another potential "bug". When you first run CM the Last Checked box updates with the new details. If you then change any setting (eg use own icons or include direction if known) the database updates exactly as it should but the Last Checked box doesn't update.
Under normal "weekly update" use you probably wouldn't change settings after initial set up but thought it might be worth reporting and seeing if you can 'sync' the information to reflect the 'true' last checked info.
This really is a great programme which makes updating a breeze Very Happy
Ash10
PostPosted: Thu Jun 23, 2011 8:39 am    Post subject: Reply with quote
Nope, that's the intended behaviour - check for updates only happens once a day* (unless PGPSW start pushing twice-daily updates Razz)
Indirectly, this is the cause of bug discussed above - whilst changing certain settings can necessitate the GPX files being regenerated from the currently downloaded databse, it isn't necessary to actually download it again. The exception to this is adding additional regions, which may require a download if they're not already cached locally.
(*unless you specify a shorter interval, or manually force a check)
BAVC10
PostPosted: Thu Jun 23, 2011 9:14 am    Post subject: Reply with quote
Ash10
Thanks for the reply - follow your logic about the download but I wonder if it would enhance the program if you included an extra box in the directories tab under POI Directory for something like Last setting changes???
Page 65 of 77
22.062 (12 Jun 24)
