sammydsammy Occasional Visitor
Posted: Thu Jun 09, 2011 6:44 pm Post subject: |
Hi Mike,
Many thanks for that. I think that's where I went wrong as I replaced everything :-( Also do I need to replace the mapsettings.cfg or is the one I had OK to use?
Many thanks for your help,
Dave |
Posted: Thu Jun 09, 2011 7:07 pm Post subject: |
If you already had warnings working on your iPhone then they will probably still work, you certainly don't need to change the mapsettings file every week that you update the ov2 files - Mike |
Posted: Thu Jun 09, 2011 7:08 pm Post subject: |
Brilliant. Many thanks for your help!
Dave |
Aerovision Occasional Visitor
Posted: Thu Jun 09, 2011 8:21 pm Post subject: |
M8TGT - you misunderstood me. The files simply would not download. I was not asking for any breach of copyright - just some help actually.
Since found that it was an Internet Explorer problem on my laptop. Downloaded them fine using Safari thanks.
Aerovision |
Posted: Thu Jun 09, 2011 8:45 pm Post subject: |
Mike / all,
A bit of help requested here please.
Everything was working fine with 1.6 - on a IPhone 3 and also on a 4.
Now, with 1.7, on the 4, cams are visible but no audible warnings.
I kept my mapsettings.cfg from 1.6 to preserve all of my favourites, but otherwise used all of the new files. What am I doing wrong???
Also, could someone help me in "converting" the EUR speedcamera icons and also about 10 POIs of my own (not speedcams) please? Point me towards what software and how to do it and I will do the work please. (Currently, with 1.7, all are small and plain red squares).
Finally, and regarding the above, how do I make the icons different for iP4 and iP3? Again, I have one of each.
Many thanks in anticipation of any assistance.
Aerovision |
Posted: Thu Jun 09, 2011 9:09 pm Post subject: |
Irfan-View is a free to use software package that can convert the bmp files to the required png format, see Here.
As for the lack of warnings when approaching a camera, have you copied all the .ogg files to the V1,7 app map folder, the newer 1,7 app doesn't flash a warning top left like 1,6 and earlier but it will read out the ogg audio file for a spoken alert when approaching a camera.
For iPhone 3G/ 3GS you need icons sized at 22x22 which is standard.
For iPhone4 you can resize the icons to 44x44 which makes them easier to see, if you want the icons displayed on the map the same size as the icons supplied with the TomTom POI files make them 32x32 - Mike |
Posted: Fri Jun 10, 2011 2:37 am Post subject: |
Hi, I've updated the database, just the OV files and now im not getting any audio alerts... i was getting everything before so now i am confused... I have even uninstalled tom tom and reinstalled. Copied iphone 4 png and ogg files from the first thread and then copied the ov files from the update. i have also copied the mapsettings.cfg from the iphone 4 pack on the first thread but no audio :-( any help greatly appreciated,
Dave |
Posted: Fri Jun 10, 2011 6:54 am Post subject: |
Thanks Mike, I will try re-sizing to 32 x 32.
I will also try 1.7 on the iP3 to see if audio works on that one. I was loath to upgrade both iPhones to 1.7 as 1.6 works fine and don't know how to revert to an earlier version if it don't work.
Has anyone else noted that the 1.7 TT prog for Western Europe is a somewhat smaller file than 1.6?
Thanks again,
Aerovision |
Posted: Fri Jun 10, 2011 4:54 pm Post subject: |
All,
Still unable to get voice alerts working at all. Having used this for 1.5 and 1.6 and having re-read the forum, I really can't see what I am doing wrong.
Next step is to throw away my old mapsettings.cfg and try Mike's new one maybe - but to loose all of my favourites......
Aerovision |
Posted: Fri Jun 10, 2011 5:42 pm Post subject: |
Make sure the app isn't running in the background when you copy the mapsettings.cfg file to the iPhone, also double check which folder you are putting it in as it's different to where you put the ov2, ogg and png files.
As for your favourites, copy the old mapsettings.cfg from the iPhone then use POIEdit to convert the file to a custom POI file and load that naming the file "_Favourites.ov2" (without the "" but the _ at the start of the file name is important as it forces the app to list the category at the top of the index for POI files making it easier to locate - Mike |
davast Lifetime Member
Joined: 19/08/2003 20:59:33 Posts: 61 Location: Warrington UK
Posted: Sun Jun 26, 2011 7:52 pm Post subject: |
If I upgrade to v1.8 with the new map, will this overwrite the cfg file & camera/voice files I used on v1.7? |
Posted: Sun Jun 26, 2011 8:17 pm Post subject: |
Every time you update the app you will need to reload the mapsettings.cfg file along with all the ov2, png and ogg files - Mike |
Posted: Sun Jun 26, 2011 10:09 pm Post subject: |
mikealder wrote: | Every time you update the app you will need to reload the mapsettings.cfg file along with all the ov2, png and ogg files - Mike |
Done that Mike. The pgpsw cameras & voice files are there. Also copied over the cfg file to the correct folder, but cameras don't show up in v1.8
Does it need a new cfg file? |
MrGumby Regular Visitor
Joined: Jan 21, 2006 Posts: 114 Location: West Sussex
Posted: Sun Jun 26, 2011 11:55 pm Post subject: |
davast wrote: | The pgpsw cameras & voice files are there. Also copied over the cfg file to the correct folder, but cameras don't show up in v1.8 |
I haven't upgraded yet, so am interested in the conclusion to this.
When you say the cameras don't show up, do you mean the PNGs don't appear on the map or just that the OGGs don't play?
If the former, I assume you've checked the settings to see that 'POIs on Map' is set to ON and the cameras are selected in 'POI types'? |
mistersaxon Occasional Visitor
Joined: 25/01/2003 17:12:06 Posts: 32 Location: United Kingdom
Posted: Mon Jun 27, 2011 7:27 am Post subject: v1.8 upgrade - first thoughts. |
First thoughts are:
1. If you have any other POI files in the data folder make sure to copy them away with Diskaid before the upgrade - looks like TT clears the folder before copying in
2. Clearly it resets the mapsettings.cfg file but NOT completely as any recent destinations that weren't from your custome POIs will still be there. I would need to do the upgrade differently but I suspect that if you copy out your mapsettings.cfg file before the upgrade and then replace the new one with your old one all will carry on as normal.
3. I worked that out later so I refreshed the mapsettings.cfg from the download on page 1 of this thread. Spoken alerts are all working as previously but not icons on screen and it still doesn't seem to include the "alert if on route" option which is a shame as I get a lot more irrelevant alerts now.
4. It would be nice to have a TomTomBackup App that saves this stuff away before an upgrade - any gifted coders out there fancy earning a few pence?
5. Multi-point routes! Welcome, my friends, to the 21st century! My old Garmin Quest could do that and it's got to be 8 years old . . . .
Anyway, nice to have new maps. I wonder if TomTom are wondering how they can get iPhone customers to pay for these now they've been giving them away for so long. Knowing TomTom it'll be a "new" app... _________________ <br>
Rich.
Kit: TomTom iPhone WEurope on iPhone6s+ / iPad Pro
w/ Interphone BT headset on a Honda Blackbird (should change this really - the bike, not the headset) |
