Pocket GPS World :: View topic - How store trip information after turning the device off&
ynykon
PostPosted: Tue May 24, 2011 4:06 pm    Post subject: How store trip information after turning the device off& Reply with quote
Hello.
I use Igo 8.3 for 2 years, very happy.
Everything in this application is OK for me, except of one problem that I could not solve yet. Namely - as soon as the device is turned off, all the statistics of on-board computer are lost. This happens quite frequently and involuntarily - for example, I stop to refuel, turn off the ignition - supply of energy on the lighter is stopped and the unit switches off. And I need that information about the moving time, distance, average speed remains even after turning the device on and off.
How can I do it?
I know that the onboard computer has several slots to save the trips (Trip 1, Trip 2 ...), but I do not how to use this feature. On my device Tab “Travel 1” is always used, but when you turn off the device data from there are reset too..
I would be grateful for the help.
ynykon
PostPosted: Wed Jun 08, 2011 1:06 pm    Post subject: Reply with quote
I do not believe that no one here have met this problem
Any suggestions?
PostPosted: Wed Jun 08, 2011 2:38 pm    Post subject: Reply with quote
I have iGO8 and the trip does not do this for me. I believe there is a setting, perhaps only in a third party skin, that will reset the trip when you start a route. I have got it set on mine, and it does not reset any of the three trips on a standard powerdown. On mine, using GJ skin, it's in Settings~Map Screen~TC Settings~Auto reset TP.
You can stop the unit auto switching off by editing the Sys.txt file in the interface section include the line shutdown_time=0 as below.
[interface]
shutdown_time=0
or change the number to however many seconds you want the delay.
I seem to have the problem that if I let it auto shutdown, the recovery mostly does not work correctly, so I have to shutdown again manually and restart. Because of this I have disabled the auto shutdown.
22.055 (29 May 24)
