jamieboyle Occasional Visitor
Posted: Sat Jun 04, 2011 10:52 am Post subject: Nissan Connect - Note wont upload new POIs |
Hello
any help would be appreciated.
I have 2010 (60) nissan Note with connect sat nav. i have tried to install speed cameras but it gets as far as loading new POIs as then freeezes. i ahve tried waituing more than 30 minutes so i take it there is an issue.
I hae aslo tried 3 different USb stick!
Help please |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15412 Location: Bradford, West Yorkshire
Posted: Sat Jun 04, 2011 12:39 pm Post subject: |
Has it ever worked before or is this your first attempt?
If it has worked before has there been a software update at all? Nothing has changed in the generated files...
MaFt |
Posted: Sat Jun 04, 2011 12:45 pm Post subject: |
No
This is the first time i have tried but to no avail. |
ypkel01 Occasional Visitor
Joined: Aug 31, 2009 Posts: 10 Location: Hemel Hempstead
Posted: Sat Jun 04, 2011 7:21 pm Post subject: Won't upload? |
I Have had this problem two or three times and have found it usually gets sorted on the next download. I have usually used a previous download until it gets sorted. My file wouldn't work this week either. |
dalek Occasional Visitor
Joined: Mar 14, 2006 Posts: 19 Location: Northants. UK
Posted: Thu Jul 21, 2011 9:03 am Post subject: |
Just to confirm that you have the files in the correct structure on your memory 'stick'. Usb drive then folder called myPOIs, inside that folder a folder called myPOIWarnings then inside that folder only the excel type files, for example pocketgps_uk_sc. Only files in this folder will give warnings. If you put files in previous folder (myPOIs) you just get access to find or navigate to these. For example I have downloaded all the UK Nissan dealers here and other location sets or interest to me.
NOTE that these file names are case sensitive.
Let us know if it cured your issue. |
Andy_P Pocket GPS Moderator
Posted: Thu Jul 21, 2011 11:00 am Post subject: |
dalek wrote: | ......then inside that folder only the excel type files, for example pocketgps_uk_sc. |
Just to avoid any confusion....
The full name of that file will be pocketgps_uk_sc.csv (for the UK camera data).
It sounds like you may not have Windows set to show you FULL filenames, Dalek?
For info, the Speed Camera Database Installation Guide: Nissan Connect does already show the folder structure you suggested and the correct filenames of what to put in it.
*To show full filenames in Windows XP...
In Windows Explorer or My Computer, go to the TOOLS menu / FOLDER OPTIONS / VIEW Tab /
In the "Advanced settings" section:-
UN-Tick "Hide extensions for known file types"
(Win7 will be similar) _________________ "Settling in nicely" ;-) |
airbrusher Occasional Visitor
Posted: Thu Jun 21, 2012 2:36 pm Post subject: Nissan Juke |
Hi Guys iv got a 2011 Juke as of January,loaded the camera updates from here, (Nissan connect)but it seemed to stop 50% so i switched the ignition off then back on again, started the car and it went strait in,
This might work with others |
