Pocket GPS World :: View topic - v10.200 software and new features for the Go1000 at last!
Goto page 1, 2, 3  Next
PostPosted: Tue May 24, 2011 12:24 pm    Post subject: v10.200 software and new features for the Go1000 at last! Reply with quote
TomTom has just released v10.200 software for the GO 1000 / GO 1005 and some VIA models.
At last, the long promised ability to load POIs, voices, Warning sounds etc. has been implemented.
I've been lucky enough to have a sneak preview of this functionality, and it works well.
It's still a long slow process to load stuff, but even that may be improved soon.
(GO 1000 series, Via series)
* Allows you to use MyTomTom to install third party POI sets, community voices, warning sounds, start-up and shut-down images, car symbols and colour schemes.
* Improves map installation process
This is what you should see in myTomTom now.
"Settling in nicely" ;-)
cooldood
PostPosted: Tue May 24, 2011 1:34 pm    Post subject: Reply with quote
What format do the warning sounds have to be as it wont let me upload the .ogg sound files for the cams?
PostPosted: Tue May 24, 2011 3:10 pm    Post subject: Reply with quote
I'm using ogg files OK here.
There was some problem uploading them but I thought it had been sorted.
But you could try .wav?
I don't think mp3 are ever going to work.
PostPosted: Tue May 24, 2011 3:49 pm    Post subject: Reply with quote
I just tried it again and uploaded another .ogg sound file successfully, but I'm on a slightly earlier software version.
One thing to mention is that the sounds are not being sorted alphabetically, so check to see if they HAVE uploaded but just got buried in the list.
cooldood
PostPosted: Tue May 24, 2011 4:31 pm    Post subject: Reply with quote
when i try to install them it tells me..... the poi set you are trying to use cannot be used with your device. check you have the correct file.
i will try converting them to wav format and try again
cooldood
PostPosted: Tue May 24, 2011 4:45 pm    Post subject: Reply with quote
converted them to wav and get exactly the same response Confused
technik
PostPosted: Tue May 24, 2011 5:41 pm    Post subject: Reply with quote
It doesn't actually provide you with any new map colour schemes, or icons, voices etc like the old Home used to do.
GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D
jmcmtank
PostPosted: Tue May 24, 2011 9:33 pm    Post subject: Reply with quote
Got my ogg camera warning sounds on OK, tested and they work fine......just a shame I loaded the wrong set initially, just as slow to delete files as load them! Oh yeah, now have a retro start up splash screen from a previous device.
jmcmtank
PostPosted: Tue May 24, 2011 10:48 pm    Post subject: Reply with quote
Are you scrolling down the page to "Community warning sounds on device +Add Warning Sound"?
cooldood
PostPosted: Tue May 24, 2011 11:42 pm    Post subject: Reply with quote
Yes I was. I shut the pc down to go out when I came back I tried again and the option was there. Installed then deleted so I could rename them, I can now assign them without going through every single one to find the correct one.
Tomtom 1005 but wish I had kept my 550 live
Gee-Pee
PostPosted: Thu May 26, 2011 8:54 am    Post subject: Reply with quote
Got an email from TT this am pointing me to the updated info on this subject ...see here
Gives all the info on the updated 'Community content' function of MYTomTom Wink
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
HummerUK
PostPosted: Thu May 26, 2011 5:59 pm    Post subject: Reply with quote
I see the PC software has also updated again to 3.0.2.344
HummerUK
Gee-Pee
PostPosted: Thu May 26, 2011 6:20 pm    Post subject: Reply with quote
HummerUK
Yes, just updated mine. Wink
Gee-Pee
mjdj1689
PostPosted: Thu May 26, 2011 9:06 pm    Post subject: Reply with quote
Not had a chance to look at this, so instead of a page where you can get the voices like on the old tomtom now you just add poi and it gives you a list of voices pois , is this correct ?
vickusin
PostPosted: Thu May 26, 2011 11:56 pm    Post subject: Reply with quote
Just had a go at uploading something into each category to see what would happen. I had a lot of personalised stuff in my old Go 950. I tried warning sounds, car symbols, map colour schemes, voices and a startup screen - they all seem to have gone in OK and are working.
It seems that TomTom are finally heading in the right direction with this. Still a few thigs that need adding, like Map Share and additional voices, but they're getting there.
Page 1 of 3
23.021 (05 Feb 25)
