Pocket GPS World :: View topic - Garmin car chargers output voltage and current
Chipstix
PostPosted: Tue May 24, 2011 11:18 am    Post subject: Garmin car chargers output voltage and current Reply with quote
Please could someone confirm for me that both the below 12v Garmin cigar lighter adapators are compatible with my Garmin Nuvi 760? I.e. compatible voltage and current?
The miniUSB connector is the same.
The reason that I ask is that I have an old spare Garmin charger from when I had a Garmin i3, and when I power my Nuvi on my motorbike, I would prefer to use this rather than the traffic-antenna-equiped power adaptor that came with my Nuvi (I realise I will not get traffic info, but I don't require this for leisure use and it will be neater without the antenna to deal with).
I have this type
http://www.nectar.com/nectar/cse/view/159977380
and this is the adaptor that came with the Nuvi
http://www.google.co.uk/search?um=1&hl=en&safe=active&rlz=1T4GGLS_en-GBGB403GB403&biw=1326&bih=482&tbm=isch&sa=1&q=garmin+GTM-21&aq=f&aqi=&aql=&oq=
I need to check that the miniUSB is still accessible with the Nuvi back plate fitted (as the GTM-21 adaptor has a wider connector that fits into this backplate)
Many thanks, Chipstix
PostPosted: Tue May 24, 2011 12:52 pm    Post subject: Reply with quote
Any charger that uses a USB, mini USB or micro USB connector will output 5 Volts, so that's OK.
Almost all car chargers will be capable of supplying around 1.5 Amps, to allow use and a decent rate of battery charging simultaneously. If yours can provide something like that, they will be OK.
Home chargers are similar, but if you use a PC USB connection, that is limited to 500mA so charging will be much slower, especially if you are also using the device.
"Settling in nicely" ;-)
PhilHornby
PostPosted: Tue May 24, 2011 12:58 pm    Post subject: Re: Garmin car chargers output voltage and current Reply with quote
I've not seen an I3 charger in the flesh, but so long as it's rated 5V 1A and contains the 'personality resistor' between Pins 4&5 it will work.
The downsides of using a USB-based charger with the 7xx series are:
  • It's obviously nothing like as convenient, as having power supplied by the cradle.
  • Longevity of the USB socket is an issue. (It's the Achilles heel of many lesser Garmin units, where you have no choice but to use it)
  • The display brightness does not adjust automatically when powered by USB.
Have you considered the 'ordinary' Vehicle Power Cable (010-10747-03)?
If you type that Product Code into eBay, you'll find a seller in Hong Kong, that has them for less than a fiver including shipping. I've used them in the past and found them perfectly acceptable.
PostPosted: Tue May 24, 2011 1:12 pm    Post subject: Re: Garmin car chargers output voltage and current Reply with quote
Ah yes... I forgot that little niggle with Garmin devices!
Without it the unit will either go into PC mode or just power down after a certain period as it thinks it is attached to a PC.
Does it have to be a resistor though?
There's a recent topic here on bodging an existing charger by just putting a short between the two pins.
How To Hack A USB Charge Cable
PhilHornby
PostPosted: Tue May 24, 2011 1:32 pm    Post subject: Re: Garmin car chargers output voltage and current Reply with quote
AIUI, they use different value resistors to identify the connected device. (Car charger, Wall charger, Fleet Management Cable, Traffic Receiver etc). Presumably a dead-short is interpreted as something ...
Personally, I've never succeeded in accessing Pins 4/5 in an existing mini-USB - though I suppose it should be possible.
I did try to buy some mini-USB 'B' plugs to make my own, but the ones I chose (from Maplins) only allowed access to Pins 1,2,3 & 5. The store manager insisted there are only 4 pins in a mini-USB B plug/socket - he clearly hasn't read the USB spec. Rolling Eyes
Chipstix
PostPosted: Tue May 24, 2011 1:43 pm    Post subject: Good tips Reply with quote
Interesting info, cheers guys.
In that case, for now I think I am making it more complicated than it needs t be.
I'll use the correct standard charger via the cradle. That way, the unit will act as if it is just in a car.
I plan on using a length of cable weave sheathing to keep the various wires that come up from under the front of the seat and over the tank so I will run the antenna through there too which will keep it tidy and out of the way.
Cheers, Chris
Ash10
PostPosted: Tue May 24, 2011 3:26 pm    Post subject: Reply with quote
On some Nuvis you can boot them off batteries, press and hold the battery icon to enter diagnostic mode, connect el-cheapo USB cable, then quit out of the diags back into the main UI - then use as normal.
22.123 (18 Dec 24)
