Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Fri May 20, 2011 8:57 am Post subject: POI Icon corrupted after install Map v870 |
Just installed the updated v870 map on my GO950Live - took forever to DL and install W & CE Map (1hr 40min for download and further 21 mins for install).
Device is VERY slow since the update and this am have noticed that the POI icon for a set of POIs that I wrote and installed myself no longer is visible against the individual POIs - the default red box is shown instead. I have checked the bmp files using Explorer and they are still there. The POI set is installed on my GO1000Live and works perfectly - so what has happened
Suggestions as to how I should get the POI icons back would be appreciated. Reinstall the whole set ? _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Oldboy Pocket GPS Moderator
Posted: Fri May 20, 2011 11:59 am Post subject: |
A quick, stab-in-the-dark, answer would be to try a Reset. ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Richard
Posted: Fri May 20, 2011 12:25 pm Post subject: |
Oldboy wrote: | A quick, stab-in-the-dark, answer would be to try a Reset. ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Sensible suggestion, Richard - did try that....and it keeps resetting itself too many times for my liking Perhaps a factory reset might help, but I am reluctant as it puts me to too much work. _________________ Gee-Pee
dhn Frequent Visitor
Posted: Fri May 20, 2011 12:49 pm Post subject: |
What's the size of the .bmp, Gee-Pee? 22x22? 24x24?
Maybe the app on that model is more finicky about the appropriate .bmp size. _________________ David |
Posted: Fri May 20, 2011 1:54 pm Post subject: |
dhn wrote: | What's the size of the .bmp, Gee-Pee? 22x22? 24x24?
Maybe the app on that model is more finicky about the appropriate .bmp size. |
Hi David. It's 22 X 22. Has been working perfectly for about a year since installation. I think I will just try to re-install and see what has happened, although that should not work, as the bmp file seems to be OK within the device when I look via Explorer. _________________ Gee-Pee
Posted: Fri May 20, 2011 7:06 pm Post subject: |
Problem sorted. I don't know how this happened but I found that the POI icon for the POI set had migrated itself into the N American map folder whilst the ov2 file was in the Europe folder. Cannot imagine how that happened, but it must have been me......... Don't tell anyone
Found this after doing a factory reset.
But, at least I can sleep tonight. _________________ Gee-Pee
