Pocket GPS World :: View topic - Help with iGO8 and speed limits
Red47
PostPosted: Sun May 08, 2011 10:39 pm    Post subject: Help with iGO8 and speed limits Reply with quote
Just purchased from a Sat Nav from Hong Kong with iGO8.
Vs 8.3.4.142975
The problem is that it shows UK speed limits in metric equivalent e.g. 30mph is shown as 48mph and so on. So you've got be doing over 48 in a 30 zone to get it to register that you're speeding. I haven't tried this but I was just over thirty at one point and it did not respond so I am assuming that this to be the case.
My question is that is the sat nav faulty or is there a setting somewhere that I've missed in the manual?
Any help gratefully received
Border_Collie
PostPosted: Mon May 09, 2011 1:15 am    Post subject: Reply with quote
Settings/Regional.
Units will show Kilometres/metres, tap on the line and it will change to Miles/feet, tap again to get Miles/yards.
If you want to be warned if you are speeding, Settings/Warnings, tap on Warn When Speeding, a tick will appear in the box, then tap on the rectangle with three dots, to the right of it.
Change In Built-up Areas to 110% and Elsewhere to 105%, otherwise you will get a warning when you go 1mph over.
PostPosted: Mon May 09, 2011 8:21 am    Post subject: Re: Help with iGO8 and speed limits Reply with quote
I don't think so.You probably didn't have 'Warn when speeding' set. The whole unit is in metric including speed in KPH if you have the metric option set. One thing to remember is that the speed limits come from the map data, so are subject to being wrong and incomplete, so don't rely on the speed limit from iGO.
Red47
PostPosted: Mon May 09, 2011 3:47 pm    Post subject: Reply with quote
Thanks for the replies.
I've have already done all the things suggested with no joy.
I probably haven't explained the problem properly but here goes again.
The unit is saying that the speed limits in the UK are:
48mph, 64mph, 80mph, 96mph
not the correct speeds
If you convert correct UK speed limits to kph you get the figures shown so somehow the unit has got confused about mph speed limits and their metric equivalent and is saying that the metric speed limit is the mph speed limit.
Would updating the UK map help or is the problem elsewhere?
Any thoughts?
PostPosted: Mon May 09, 2011 6:30 pm    Post subject: Reply with quote
What map version do you have? Settings~About~Maps (on my unit with a non standard skin)
Red47
PostPosted: Mon May 09, 2011 6:57 pm    Post subject: Reply with quote
Found it:
United_Kingdom_83_TA_2010.12_110210.fbl
PostPosted: Mon May 09, 2011 7:31 pm    Post subject: Reply with quote
One issue later than mine. UK TA maps do have the correct data for displaying MPH, so I can't think of what else to do. Have you put the speedcams from here on it? If so, do they give the correct speed readout?
Red47
PostPosted: Mon May 09, 2011 7:44 pm    Post subject: Reply with quote
Thanks for the reply.
No I haven't tried any other speedcam data on as it is a brand new unit. I shall be contacting the seller regarding this problem.
Thanks for your help.
windsor
PostPosted: Sun Jun 05, 2011 12:34 pm    Post subject: Reply with quote
The 2010 Q4 teleatlas maps have the speed limit data wrong. You will have to revert to an earlier map, or wait & hope that TA correct it in 2011 Q1
Geoff
