Pocket GPS World :: View topic - code confusion ???
code confusion ???
thedogwalker
PostPosted: Sat Apr 16, 2011 10:38 pm    Post subject: code confusion ??? Reply with quote
hi all, just got my satmap today and im trying to plot route for 24 peaks challenge (unfortunately not online anywhere to steal) !! so ive found the route i want here http://explore.ordnancesurvey.co.uk/os_routes/show/1843
BUT, the grid references which for example are "GR 194150" wont work on the online route planner page, do i need to convert them to another format? how?
any help greatly appreciated, thanks.
chris aka thedogwalker. Wink
JimmyTheHand
PostPosted: Sun Apr 17, 2011 9:57 am    Post subject: Reply with quote
GR - I assume refers to Grid Reference - and the six numbers is the reference. That is OK if you are using a map, but for a a GPS you'll need the Grid Square (NY in this case I believe - set the Route Finder to show OSGB & GB OS in top right)
so it will be something like NY194150
J.
JimmyTheHand
PostPosted: Sun Apr 17, 2011 2:25 pm    Post subject: Reply with quote
I am not sure the route shown on map matches the trail described - as it doesn't go through start point or bridge described
if putting into satmap - 6 figure reference is +/- 50 mtrs, satmap will show 10 figure references - OS grid references
J.
thedogwalker
PostPosted: Sun Apr 17, 2011 8:49 pm    Post subject: Reply with quote
thanks ill try, when i enter the code in search box what goes in the "as a " box?
also is there a best way or easier way to plot this route ?
rothers
PostPosted: Sun Apr 17, 2011 9:57 pm    Post subject: Reply with quote
I'd use something like The Hug:
http://maps.the-hug.net/index.php
Jospee
PostPosted: Mon Apr 18, 2011 10:26 am    Post subject: Reply with quote
or http://www.walkhighlands.co.uk/maps/ - register for free and you can plot on 1:25k maps
23.054 (28 May 25)
