Pocket GPS World :: View topic - Mapopolis Drivers
Mapopolis Drivers
jase
PostPosted: Thu Aug 12, 2004 8:15 am    Post subject: Mapopolis Drivers Reply with quote
Can somebody tell me if the mapopolis software has it's own gps drivers built in. If i removed anything to do with tom tom from my pocket pc would then mapopolis look at my fortuna clip on b.t. gps on com 6?
jason
PostPosted: Thu Aug 12, 2004 1:29 pm    Post subject: Reply with quote
Yes, Mapopolis has it's GPS driver built in. (to be blunt : there is no need for a separate GPS driver. All you need to do is to read the serial buffere every now and then ;-) )
Tiy don't need to remove TomTom . You only need to remove the TomTom GPS driver. Make sure it is really gone, and don't forget the soft resets
jase
PostPosted: Thu Aug 12, 2004 2:29 pm    Post subject: Reply with quote
hi lutz
well i removed the tom tom gps driver. Completed a soft reset but it still won't see com6. Tried setting to com 4 in my bluetooth manager settings but the gps unit won't see anything.
Any other suggestions mate. I wish i had never changed the ****** thing
:D
jase
PostPosted: Thu Aug 12, 2004 3:08 pm    Post subject: Reply with quote
you may be looking at the wrong port... What Pocket PC are you using?
jase
PostPosted: Thu Aug 12, 2004 3:33 pm    Post subject: Reply with quote
Hi lutz
I am using pocket pc version 4.20.0. On XDA II.
I've tried com4 for the inbound com port and checked it in the bluetooth settings and also unchecked the inbound com port.
Does a soft reset have to be done each time i check & uncheck?
Sorry for all these questions.
jason
PostPosted: Thu Aug 12, 2004 3:53 pm    Post subject: Reply with quote
you are consuming the service of the BT receiver, so you need to use the OUTGOING port.
jase
PostPosted: Thu Aug 12, 2004 9:26 pm    Post subject: Reply with quote
Hi lutz
Thanks for that it worked, now to get the tom tom driver installed as well again.
Jase
PostPosted: Thu Aug 12, 2004 9:40 pm    Post subject: Reply with quote
You can install Version 2.07 from our downloads page.
