Pocket GPS World :: View topic - Importing POI to a TomTom Carminat using HOME
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop
lundavra
PostPosted: Sat May 15, 2010 11:40 am    Post subject: Importing POI to a TomTom Carminat using HOME Reply with quote
I am trying to import some POI to the TomTom Carminat built into my Renault.
I can convert the .GPX file to .OV2 and .ITN but I cannot get the TomTom HOME program to see these so I can transfer to the memory card. I have done it once before and can't I remember how I did it (I know I had a lot of problems then).
I must spent at least an hour trying different ways but can't get anywhere.
I wonder if anyone can suggest how to do this?
It is really frustrating, I could do the same in a couple of minutes with my old Garmin!
MB
Anita
PostPosted: Sat May 15, 2010 11:45 am    Post subject: Re: Importing POI to a TomTom Carminat using HOME Reply with quote
If you're just transferring the files from your computer to a memory card you don't need to use HOME. Just copy the files to the card using Windows Explorer.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
lundavra
PostPosted: Sat May 15, 2010 11:53 am    Post subject: Re: Importing POI to a TomTom Carminat using HOME Reply with quote
I was wondering about doing that, will give a try.
MB
wwhite139
PostPosted: Sat Mar 26, 2011 9:43 am    Post subject: Carminat Reply with quote
Just a short note to let you know that I have a carminat system in my Laguna Coupe, and have successfully added the camera database (TomTom OV2 consolidated by type) files to the system as described here by pocketgpsworld, namely putting the sd card into a reader on the PC/ Laptop and copying the files into the map folder. You do have to set the distance for each speed group warning individually, but that is a once only operation. Next time just drag and drop the new database files into the same map folder on the sd card and "overwrite" the existing ones. As a side note, I have discovered that pressing the "Mute" button twice quickly, disables the warnings when not using the sat nav in guide mode, and can be re-enabled by pressing the "Repeat" button once. Would like someone else to corroborate this or is it a fluke ?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop All times are GMT + 1 Hour
