Pocket GPS World :: View topic - Changing splash screen
thefella
PostPosted: Sun Mar 13, 2011 11:19 pm    Post subject: Changing splash screen Reply with quote
Is it possible to change the splash screen (start up screen) on a 1490tv?
Pocketgps
PostPosted: Mon Mar 14, 2011 1:22 am    Post subject: Reply with quote
Garmin use to have a program called xImage that could load a different start screen etc. Not sure if they still have it on their web site or if it will work with the latest units.
PostPosted: Mon Mar 14, 2011 2:25 am    Post subject: Reply with quote
From a quick Google for "change the splash screen on garmin 1490"
1 - Turn on the Nuvi
2 - From home screen click settings
3 - Click display
4 - Click "Change" beside splash screen
5 - Choose any JPEG already listed on your Nuvi or SD card
For best results resize your image to be either 320x240 or any size ratio of 1.33 (such as 1024x768, i.e. divide the length of the image by the height). If you don't use a 1.33 aspect ratio your splash screen will be cut off at either the bottom or sides.
I think that should work for your model.
thefella
PostPosted: Mon Mar 14, 2011 6:28 pm    Post subject: Reply with quote
There is no change under display settings in that menu! I've tried the xImage and that wont recognise the device! Sad
Just had a go again, and you go into the picture folder and display a picture then push i button on left, it asks if you want that displayed at the startup screen.
Cheers for your replies Very Happy
inthe128
PostPosted: Thu Mar 24, 2011 8:17 pm    Post subject: Reply with quote
I just bought a 1490 and if you load an image into the picture viewer then click on that image, it gives you a box to tick for the image to used on start up
SORRY 4 days to late..... Embarassed
in the 128
