Pocket GPS World :: View topic - Forced Home & Navcore updates. Is 9.058 safe?
Goto page 1, 2, 3, 4  Next
wildcard
PostPosted: Mon Mar 21, 2011 3:06 pm    Post subject: Forced Home & Navcore updates. Is 9.058 safe? Reply with quote
I see from the other threads - the latest Home update is a forced upgrade and once done it then prevents an opt out of the Navcore update . I currently run a 940 with 8.371 and have avoided 9.058 until now due to all the problems reported here.
Should I go ahead with the Home and Navcore upgrades or wait and hope TT back off this dictatorial policy. I use the Live traffic service and do not want to lose this - could probably live without Google and the rest.
Regards
Guivre46
PostPosted: Mon Mar 21, 2011 3:30 pm    Post subject: Reply with quote
From what I read the problems with x40s and 9.058 depend on which version of the internal SIM card you have in your device. There is a thread on here somewhere that refers to this.
There's this: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=84557&postdays=0&postorder=asc&highlight=sim&start=0
But I thought I'd read some references to actual SIM serial numbers.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
franb
Banned
PostPosted: Mon Mar 21, 2011 5:02 pm    Post subject: Re: Forced Home & Navcore updates. Is 9.058 safe? Reply with quote
Regards
Yes, go for it. Very, very few (if any) have found fault with it.
PaulB2005
PostPosted: Mon Mar 21, 2011 5:08 pm    Post subject: Reply with quote
Few x50 owners had problems. Many x40 owners did though.
PaulB2005
PostPosted: Mon Mar 21, 2011 5:18 pm    Post subject: Reply with quote
There are also a number of bugs 9.058 which have been well discussed here.
matthewj
PostPosted: Mon Mar 21, 2011 5:45 pm    Post subject: Reply with quote
FWIW, I think the upgrade is worth it overall. Yes, there are some bugs (and it was good to hear of a beta for an update!), but it is a nicer system as-is, and I stick with it. That said, I do have it on an SD card so that if it all goes horribly wrong I can pull the card and I'm on the old firmware. But I've never felt I needed that yet.
PaulB2005
PostPosted: Mon Mar 21, 2011 6:10 pm    Post subject: Reply with quote
As per my signature I stuck with it but I suspect most of that I down to the fact I hardly use it anymore. If I had use it on a day to day basis the bugs would cause me to revert back to the NavCore 8.
Either I missed franb's sarcasm or franb missed the dozens of pages on here discussing the faults. Oh and the poll......
franb
Banned
PostPosted: Mon Mar 21, 2011 7:47 pm    Post subject: Reply with quote
No sarcasm whatsoever.
Just my own observations on a dozen or so x40's & x50's using 9.058 compared with any previous versions.
PaulB2005
PostPosted: Mon Mar 21, 2011 8:23 pm    Post subject: Reply with quote
So none of them suffer the following issues?
1) Automatic 3D/2D switch does not work as described. If you set the unit to use 3D when following a route, it doesn't. You have to manually switch it yourself.
2) Route doesn't clear when you reach your destination.
3) If you switch the unit off with a route still set the battery runs down a lot quicker than if you don't.
4) Traffic Bar doesn't appear for 3-5 minutes after switching on. Now this only seems to apply to the x40s but it is a real issue.
TomTom have admitted this issues affect quite a few customers and they are working on a new NavCore (9.012) at the minute. Coupled with the threads here surrounding these problems I find your assertion that "Very, very few (if any) have found fault with it" to be laughable at best. I would suspect the truth is "some have issues, some don't" which is far from your claim.
PaulB2005
PostPosted: Mon Mar 21, 2011 8:49 pm    Post subject: Reply with quote
In fact I'll see your dozen units without issues and raise you 21 that do - here
Out of the 40 that responded 21 had issues on both x40 and x50 models.
falkirk81
PostPosted: Mon Mar 21, 2011 11:01 pm    Post subject: Reply with quote
Paul, on that note, have any x40 owners actually been brave enough to try out the 9.120 software?
I have it on my 950 and have had no issues. A couple of minor cosmetic changes as mentioned in the thread.
I wonder if this new navcore fixes some of the issues that current x40 users face?
Steven
Tomtom GO 1005 LIVE
iPhone 12
PaulB2005
PostPosted: Mon Mar 21, 2011 11:08 pm    Post subject: Reply with quote
Steven
Yes, i did. It fixed many of the problems but i couldn't get the LIVE Services to work. here
Also the definative list of faults with 9.058 is there too (on the previous page)...
1. Screen Changes to 2D Mode From 3D Mode When A Route is Cleared and Does Not Change Back to 3D Mode When A New Route Is Selected.
2. Battery Runs Down Quickly When The Unit Is Powered Down Unless Clear Route Is Used Before The Unit is Turned Off.
3. Route is Not Cleared Automatically When "You Have Reached Your Destination" is Announced
4. Announcemement of Arrival At A Way Point and/or Verbal Count Down of Distance to Arrival At A Way Point (eg Petrol Station) does not work
5. No Verbal Announcement That Traffic On Your Route Has Changed, Even Though Options Are Set For The Unit To Do This. In Navcore 8.371 This "Traffic Has Changed" Announcement Was Read Out When There Was New Traffic Info On Route.
6. Petrol Prices - Still Many Dead Stations in Database or Stations With No Price Update For Many Weeks or Months.
7. Google Live Search Does Not Work Properly For Many Destinations and the POI is Often up to a Mile Out Compared to the Actual Place on the Ground.
8. Basic Road and Place Address Details Are Not Shown Against A Petrol Station POI WIthout Using Show Info and This is Greyed Out Nearly All The Time For Petrol Stations.
9. Heavy Screen Pressure Required For Input To Be Recognised on 940 Unit Compared to Screen Pressure Required Under Navcore 8.371 on my 940 or Pressure Required for X50 Unit With Navcore 9.058
10. Volume Sometimes Impossible To Increase From Low Level Setting in 3D View When On The Move. Have to Change to 2D View To Change It.
Not sure about all of them though i thought 5 was still working but.... Confused
PostPosted: Tue Mar 22, 2011 1:34 am    Post subject: Reply with quote
WHO's "definitive list"???? (oh, it's the banned Wacky Races....)
It's a very odd list... a combination of bugs, misconceptions and his personal "wishlist" as far as I can see!
My 940 does this OK.
I have it in 3D mode with a route planned. I can go to Clear Route in the menu. The display stays in 3d.
Never noticed. I use it on the charger in the car, but spend a lot of time playing with it in front of the PC.
When it runs low, I stick a USB cable in. Simples.
Can't remember.. not going out now to check! But I think it does, or it doesn't bother me if it doesn't!
Has anyone ever said this is a feature? I don't think I've ever heard of it. Yes, it would be nice to have it, but it's certainly not a bug if it simply isn't there.
On mine, if Traffic changes and there is a faster route available, it DOES read that out. I can choose whether to accept the new route and if I wish I can use voice recognition to do so by
True, but absolutely nothing to do with v9.058 or any other software version for that matter. Simply an issue with the Petrol Prices database and it's useless provider.
That's GOOGLE. Try it on your PC!
Again, is this a bug? Is it any different in earlier software?
Not on my machines... I have a 940 and a 950 in front of me and I cannot feel any significant difference in touch response between them.
Never seen this!
I tried to get Wacky Races to start new topics about each of these individual issues so we could try to get to the bottom of why he was seeing so many things I wasn't. But he was far to keen to just rant at length about everything all at the same time, so I gave up.
PaulB2005
PostPosted: Tue Mar 22, 2011 7:36 am    Post subject: Reply with quote
I meant it was a list of problems mentioned by users. It wasn't supposed to be an authoritative list.
The 3D bug definitely happens on mine - as I've already said the problems happen on some and don't on others, but the situation is far from the claimed "very few had issues" I also said I wasnt sure about all of them.
The route not clearing definitely does happen with mine too as does the battery drain whilst switched off. This means that when I arrive at a destination if I forget to Clear Route when I later need to do something like search for location or plan a route the battery doesnt last long. At that point the only option is to go to the car and plug in. Not always so "simples". In the past I would have had a fully charged battery to use. No more.
Whilst I appreciate that some have trouble free units ive waited six months for TomTom to fix the problems that do exist for some users. To date nothing has materialised other than a Beta for the x50 range which doesnt bode well for the x40 users who seem to be affected by the bugs to a greater extent. Esp the Traffic Bar bug.
haiderijaz
PostPosted: Tue Mar 22, 2011 11:30 am    Post subject: Reply with quote
So guys, after all the problems what do you suggest should i go for updating my navcore on 740 or not? Please i need serious advice
Page 1 of 4
22.124 (26 Dec 24)
