Pocket GPS World :: View topic - Cant Add Mobile seen again
tanda
PostPosted: Thu Mar 17, 2011 4:16 pm    Post subject: Cant Add Mobile seen again Reply with quote
Hi, Tried to Add a mobile speed camera seen again, been reporting it for years, now its saying camera **** is not a mobile camera, am I doing it wrong or something, its always worked before, Thanks.
MOBILE:7454@30
Audi A3 Sline sat nav
Oldboy
PostPosted: Thu Mar 17, 2011 4:36 pm    Post subject: Reply with quote
What happens if you Click the camera icon?
It should fill the various boxes with the camera details. The Action Drop Down box near the top of the page should also be pre-filled with 'Mobile Seen again' when it is a Mobile.
That message should only appear if you select a non-Mobile camera.
If this doesn't help, perhaps you could go through the steps you are taking. It might highlight something.
TT Via 135 App 12.075: Europe Map v1135
253
PostPosted: Thu Mar 17, 2011 4:38 pm    Post subject: Reply with quote
I've just filled it in and went as far as submitting it, so it appears to let me do it. I havent gone the whole way though.
Bob
Oldboy
PostPosted: Thu Mar 17, 2011 4:40 pm    Post subject: Reply with quote
It's when submitting that the message appears, I believe.
253
PostPosted: Thu Mar 17, 2011 4:58 pm    Post subject: Reply with quote
Ah, right you are. Was not reading the post right.
I'll leave it alone then Smile
Bob
tanda
PostPosted: Thu Mar 17, 2011 5:06 pm    Post subject: Reply with quote
At the top It is set to United Kingdom(Yellow Part)
Then the next yellow part, camera ID 7454 then Autofill current value.
The Action is Mobile seen again
All the other details are correct, and I can see it on the map
I also clicked on "Sean Again" on the map and iot says
Processing the Speed Camera POIs
Errors were found when adding the Speed Camera:
Submitted camera ID is NOT a Mobile camera (7454).
Please use the 'back' button on your browser to correct the error(s).
7454 IS a mobile Speed camera, I can see it on your map with its ID, the ID is correct,
I have uploaded a screen capture to facebook, don't know if you can see it.
http://www.facebook.com/album.php?id=100000804682286&aid=35560#!/photo.php?fbid=190574160979405&set=a.190574157646072.35560.100000804682286&theater
(Edited to add direct image link- AP)
PostPosted: Thu Mar 17, 2011 5:16 pm    Post subject: Reply with quote
I just tried it myself (with "NOT SEEN AGAIN - THIS IS A TEST" in the comments box) and it wouldn't let me submit it either.
Same error "Submitted camera ID is NOT a Mobile camera (7454)."
Seems to be a glitch, I'll let MaFt know.
tanda
PostPosted: Thu Mar 17, 2011 5:22 pm    Post subject: Reply with quote
Good, its not just me then, Laughing Out Loud, and thanks for trying it.
PostPosted: Thu Mar 17, 2011 10:55 pm    Post subject: Reply with quote
this is really weird... all the code is correct as far as i can see and nothing has changed on that page anyway!
i'm looking into it but for now you can email MaFt AT pocketgpsworld.com with the seen again details and i will manually update it.
PostPosted: Thu Mar 17, 2011 11:56 pm    Post subject: Reply with quote
flipping heck that was a tough one to figure out!!
last night we made some changes to the menu's to make them a bit more dynamic - turns out it clashed with the submission form...
should all be normal again now!!
PostPosted: Fri Mar 18, 2011 12:16 am    Post subject: Reply with quote
MaFt wrote:
should all be normal again now!! MaFt
Do you mean normal or correct Twisted Evil
newtomoneowner
PostPosted: Fri Mar 18, 2011 12:23 pm    Post subject: Reply with quote
that might explain the following wierd behaviour..
Log out
click forum at the top then choose new posts.
you get the message "module isnt active"
on the top left click the login button..
try to login
you get a 404 error page not found and end up at this link
http://www.pocketgpsworld.com/modules/Forums/modules.php?name=Your_Account
Also some of the pictures seem to be missing and when viewed on my mates sony vaio laptop at 1024 x 600 all the links at the top of the page (free POI's , subscriber area ) etc etc are all messed up but only on that page, once you login all seems ok.
Might be this SOny laptop im on but im 250 mile from home in somerset near yeovil at the moment having a weekend break.
Call Me N3wt for short.....
Gone back to XP after trying Windows 7, it was nice but i still prefer XP
PostPosted: Fri Mar 18, 2011 2:22 pm    Post subject: Reply with quote
N3wt - you can't view 'posts since last visit' if you're not logged in (as it doesn't know who you are to check what's new since last time!)
I'll update the menu to take that into account.
PostPosted: Fri Mar 18, 2011 3:29 pm    Post subject: Reply with quote
Have you tried it since changing it? If you click 'Log in to post' It takes you to the 'This module is not active post. You can only log in from the Login thingy on the right of the menu structure. The Login from the Module not active page does not work.
PostPosted: Fri Mar 18, 2011 4:49 pm    Post subject: Reply with quote
I did test it but I'll have another look when I get home!
22.093 (18 Sep 24)
