Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 61, 62, 63 ... 75, 76, 77  Next
Ash10
PostPosted: Tue Mar 15, 2011 2:06 pm    Post subject: Reply with quote
SQUARE2024 wrote:
Ok you clever people why is it in the settings box it shows as KPH and not MPH?,also seem tohave "double" icons on some camera locations ?
1. From the help file:
Camera Manager looks at whether imperial or metric units were last used by POI Loader, and uses these as your native units
Either you last used POI Loader with metric units (kph), or more likely you haven't yet used POI Loader with imperial units (mph) - POI Loader defaults to metric.
2. Multiple POIs (or icons) at camera locations are for providing multiple warnings - for example, approach, overspeed, direction etc.
SQUARE2024
PostPosted: Tue Mar 15, 2011 5:18 pm    Post subject: Reply with quote
I will check but I am positive that the POI loader is set to mph,that is why I asked the question,but I might have had a silver haired moment Embarassed .
Just checked the POI loader and it is set for feet/MPH. Confused
Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV
SQUARE2024
PostPosted: Thu Mar 17, 2011 2:42 am    Post subject: Reply with quote
The Garmin POI loader is and was set for MPH,so how do I overcome this?
Square2024
TomTom 520
BigPerk
PostPosted: Thu Mar 17, 2011 11:28 am    Post subject: Reply with quote
Missing something here! ... if the POI Loader (I take it you definitely DO mean that and not Camera Utility) settings box says 'KPH' can you not simply change it to 'MPH' (or is it not editable)?
As for the double camera icons, I have read here that this can be the result of reversible/two-way camera installations I think.
(Navigon 70 Live, Nuvi 360)
SQUARE2024
PostPosted: Thu Mar 17, 2011 11:32 am    Post subject: Reply with quote
On the POI loader you set it for Mph or KPH mine is set to MPH,but the camera manager still shows as kph,Have just reloaded camera manager still the same now going to remove POI loader and exit camera manager to see if that helps.
Square2024
TomTom 520
SQUARE2024
PostPosted: Thu Mar 17, 2011 12:17 pm    Post subject: Reply with quote
An update... removed and re installed the POI loader with it set to MPH,
removed the camera manger [via the exit ] re install check the setting and MPH is there ...but when i attempt to change the other settings ie the icons [which are showing as "speed" not by camera type] It will not let me do it,and now to add to this the camera manager di-appears altogether from the system tray !!
I seem to be getting into a deeper hole Confused Confused .
Square2024
TomTom 520
SQUARE2024
PostPosted: Fri Mar 18, 2011 11:33 am    Post subject: Reply with quote
Come on guys a bit of help needed here Idea
Square2024
TomTom 520
Ash10
PostPosted: Fri Mar 18, 2011 11:53 am    Post subject: Reply with quote
It sounds like you may have Options - Quit after checking if no database updates are found enabled.
When you say that you can't change any settings, is the system tray icon greyed out - ie: busy or accessing the internet?
SQUARE2024
PostPosted: Fri Mar 18, 2011 12:16 pm    Post subject: Reply with quote
When I attempt to change any settings ie the timings, the camera manager exits and there is no icon in the system tray.Other than reloading each time how do I get the camera manager back ?
Square2024
TomTom 520
SQUARE2024
PostPosted: Sat Mar 19, 2011 12:46 pm    Post subject: Reply with quote
Confused Question
Please advise how to correct the problem,why does the camera manager icon not appear in the system tray ?,
Square2024
TomTom 520
dales
PostPosted: Sat Mar 19, 2011 2:30 pm    Post subject: Reply with quote
Have you tried taking the tick out of the checkbox at Options - Quit after checking if no database updates are found?
Dales.
SQUARE2024
PostPosted: Sat Mar 19, 2011 2:52 pm    Post subject: Reply with quote
I would check this if I could get camera manager to open !,a quick flash of the icon is all I get telling me it is idle.
Square2024
TomTom 520
dales
PostPosted: Sun Mar 20, 2011 3:59 pm    Post subject: Reply with quote
That behaviour is odd.
For me, the icon stays around for a good 30 seconds [ie plenty of time to start amending the settings] before the program quits and the icon leaves the system tray.
Since your copy of CameraManager.exe seems to be misbehaving (ie quits immediately, and unable to alter settings) perhaps it's become corrupt in some way. You could try deleting it and downloading another copy.
Or, wait for more advice from Ash10.
Dales.
SQUARE2024
PostPosted: Sun Mar 20, 2011 4:12 pm    Post subject: Reply with quote
[quote
Dales.[/quote]
That is what I have been waiting for............
Square2024
TomTom 520
Ash10
PostPosted: Mon Mar 21, 2011 10:17 am    Post subject: Reply with quote
Sound advice.
When Camera Manager is run, it should install its icon in the system tray (you may also see a brief flash of the settings window) - if you click on this icon, the settings window should open.
Thirty seconds after loading, Camera Manager will perform its first check for database updates - as mentioned above, this should give plenty of time to open the settings window. If autoquit is enabled, this will only happen after this initial delay (and subsequent check for updates).
If the icon never appears in the system tray, something is seriously wrong - use the Task Manager (Shift-Ctrl-Escape) to check if Camera Manager is actually running at this point.
Are you sure that the system tray icon is not just being hidden by Windows?
Page 62 of 77
22.123 (18 Dec 24)
