Pocket GPS World :: View topic - 3790T custom POI
3790T custom POI
ellick
PostPosted: Thu Mar 03, 2011 10:32 am    Post subject: 3790T custom POI Reply with quote
Seems like I can only have one custom set of POIs in my extras.
Obviously, I have Pocket gps speed camera database. However, when I load the CAMRA good beer guide it deletes the speed cameras and vice versa.
I tried the updated CAMRA guide just to see if that worked (you can try it before you buy it) but the result was the same.
I tried loading it from an SD card; same result.
I have over 2gb of free space on the unit. Is there another way of downloading this onto the unit which will work?
PostPosted: Thu Mar 03, 2011 10:40 am    Post subject: Reply with quote
You need to put all of your POI files into the same folder. You can use SubFolders if you want too.
eg if you have:
POIFolder\CAMRA\xyz.csv
POIFolder\CAMRA\abc.csv
POIFolder\SpeedCams\pgps_uk_speedcams.csv
POIFolder\shops.csv
then you tell POILoader to use the POIFolder to import POIs.
you will then see the following under Extras / Custom POIs:
CAMRA (category)
SpeedCams (category)
shops
Hope that helps?
ellick
PostPosted: Thu Mar 03, 2011 10:49 am    Post subject: Thanks Reply with quote
Thanks MaFt,
That worked fine.
Ellick.
22.094 (25 Sep 24)
