Pocket GPS World :: View topic - CN Europe 2011.40 now available
BAVC10
PostPosted: Tue Feb 22, 2011 12:31 pm    Post subject: CN Europe 2011.40 now available Reply with quote
2011.40 is now showing up as available for download under the My Garmin account
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
MichaelCahill
PostPosted: Wed Feb 23, 2011 12:26 am    Post subject: Reply with quote
Yet again Garmin is updating the 2nd last update (2011.20, issued in July) rather than the last update (2011.30, issued in October).
Anyone know why this is so?
cwog
PostPosted: Wed Feb 23, 2011 10:14 am    Post subject: Reply with quote
How did you spot that it was a down leveled map?
Wazza_G
PostPosted: Wed Feb 23, 2011 2:11 pm    Post subject: Reply with quote
I've downloaded it, but what's a down levelled map? Confused
cwog
PostPosted: Wed Feb 23, 2011 6:27 pm    Post subject: Reply with quote
one not based on the immediately previously released map
MichaelCahill
PostPosted: Wed Feb 23, 2011 7:50 pm    Post subject: Reply with quote
I have Lifetime Maps and on MyGarmin it is showing as an update of 2011.20. There is no update showing for 2011.30.
Is this a cunning way to stop "free" 60 day updates? Presumably units shipping since October/November had v2011.30 loaded but it is 2011.20 which has the update. Confused
cwog
PostPosted: Thu Feb 24, 2011 12:06 am    Post subject: Reply with quote
The MyMaps and Download history web has changed at least three times in the last few days, the notification of the update is now a separate item and not associated with any other version.
Wazza_G
PostPosted: Fri Feb 25, 2011 12:39 pm    Post subject: Reply with quote
Ta.
I don't see any improvements/corrections though! Sad
BAVC10
PostPosted: Fri Feb 25, 2011 3:37 pm    Post subject: Reply with quote
The easiest way to see improvements before downloading is to go to this page and then click on the "view interactive map" which allows you to zoom in on any part of the map so you can see the changes (if any) in your area.
https://buy.garmin.com/shop/shop.do?cID=253&pID=6299&ra=true
Ian99
PostPosted: Tue Mar 08, 2011 8:35 pm    Post subject: Reply with quote
Junction view is not working on my 1695 since the map update. Having looked into this there is no .jcv file in the .system\jcv directory.
I've reported this to Garmin but in the meantime does anyone else the same issue or have a solution?
Cheers, Ian
Burn180
PostPosted: Wed Mar 09, 2011 6:08 pm    Post subject: Reply with quote
I've just had a look in that folder and I have both files
D2504000A.sum
D2504030A.JVC
Using CN Europe 2011.40 3D
CN Europe NT 2011.40
Garmin Nuvi 3790T Firmware 4.30
Also Owned
Garmin Nuvi 200W, 760, 770, 765T
Ian99
PostPosted: Thu Mar 10, 2011 6:44 pm    Post subject: Reply with quote
Thanks for looking Burn, I have a .sum file but no .jcv file.
Phoned Garmin earlier today as it's been 3 days since my email, 20 mins wait but helpful when I got through.
Firmware 2.70 (for Nuvi 1695) was released yesterday, advised to update the firmware and re-run the map upgrade.
Ian99
PostPosted: Fri Mar 11, 2011 7:08 pm    Post subject: Reply with quote
Updating the firmware (software) on my 1695 and reloading the maps did not help. I have now received the following response from Garmin support:
"Thank you for contacting Garmin Europe. Having spent some time working on your issue this morning, it appears that there is a wider issue than relating specific to your device.
This issue has occured on a device that I tested earlier today and I have reported this to the software team. Currently, there is no fix for this, however, when I have a resolution for you, I will email you with results and guidance on how to fix this on your device."
