Pocket GPS World :: View topic - 530 goes to sleep ?
530 goes to sleep ?
mevans08
PostPosted: Sat Feb 19, 2011 8:23 pm    Post subject: 530 goes to sleep ? Reply with quote
You guys very kindly helped me to solve a POI problem yesterday which turned out to be a simple enable/disable button.
However when I started using my TomTom 530 today it keeps going to sleep after about 5 mins whether in navigation mode or not.
I tried a soft reset and also the factory reset but no luck - still nods off 5 mins after opening.
During the soft reset a black screen with tiny tech spec writing appeared and I notice that one of the parameters said
power on mode - sleep
if this is relevant ?
I have been using it on direct plug in power - the battery only holds a charge for about 1 min as the unit is several years old and I have never replaced the battery - could this be a factor ?
Battery saving preferences shows 2 options :
. never dim screen
. dim screen between instructions
and I have tried it both ways but doesnt stop it sleeping.
also shows 'switch off when external power lost' and again I have tried it with this enabled/disabled and makes no difference.
Any suggestions much appreciated.
Many thanks in advance of a solution ! Smile
Mike[/i]
PostPosted: Sat Feb 19, 2011 8:50 pm    Post subject: Reply with quote
If its not moving and there is no interaction with the screen then it will go to sleep after around 20 minutes this is how its intended to work - Mike
mevans08
PostPosted: Sat Feb 19, 2011 9:57 pm    Post subject: Reply with quote
Thanks for the quick reply - don't you guys ever sleep Smile
Well I've never noticed it doing it before - but I guess theres a first time for everything - I'm away off to work in a minute so I'll try it again but for sure during the day today while navigating from A-B the bloody thing kept shutting down within 5 mins of being opened.....
Fingers crossed it'll behave tonight otherwise I'll be a very lost recovery driver Smile
Cheers for now.
Mike
PostPosted: Sat Feb 19, 2011 10:09 pm    Post subject: Reply with quote
If it's doing it while you're driving and it's navigating, then that's a problem rather than a feature!
Could be the battery on it's last legs I suppose - pulling down the voltage rails.
Are you sure the cigarette lighter adapter was getting power from the socket reliably?
Oh, by the way.. the "Power on mode=sleep" line is bit of a red herring. IIRC it is just telling you how it last shut down.
So if you turn it off using the power button, it will say "Power on mode=Power down" - which sounds worrying, but isn't!
franb
Banned
PostPosted: Sun Feb 20, 2011 11:10 am    Post subject: Reply with quote
You could always try running clearflash as that often cleans "bugs" like that out.
I had a 540 that did that for no obvious reason/wrong settings etc and it worked for me.
mevans08
PostPosted: Wed Feb 23, 2011 6:51 pm    Post subject: Reply with quote
Thanks for the advice guys - working ok now - goes to sleep when connected to my pc but when connected in vehicle now works continuously without a prob.
Your help much appreciated - thanks
Mike
22.064 (26 Jun 24)
