Pocket GPS World :: View topic - Torch 9800 massive freezing problems
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
mbenda
PostPosted: Mon Jan 31, 2011 11:46 pm    Post subject: Torch 9800 massive freezing problems Reply with quote
I tried to install Telmap5 V 5.25.37 on my Torch.
I can start the application but on the 1st screen I have a constant freeze after 1/3. I can change to homescreen etc. for some times but then returning to Telmap5 the screen turns black. Sometimes the BBkey gives options to close/change application sometimes it works but most times it freezes for a certain time. Even an accu-pull and un- and re-installing did not resolve the problem. Even the install-option BES / BIS did not change anything (I currently use WAP for inet-connection and everything else works fine).
As I can see many Torch-users encountering heavy problems I would suggest to open a specific Torch-sub-topic where all Torch issues are collected in !
Thank you !
SyBorg
PostPosted: Tue Feb 01, 2011 9:50 am    Post subject: Reply with quote
I've not had more problems with my Torch than I had with my 8900 as far as Telmap goes. It doesn't freeze for me.
The issues I do have are
    a concern over the reliability of speed camera alerts
    an issue with the adverts stopping search when you press the R key
Other than that it works pretty well and is a much nicer interface than the 8900 version.
mbenda
PostPosted: Tue Feb 01, 2011 2:11 pm    Post subject: Reply with quote
Thanks! But could you tell me what configuration your torch has maybe its a FW/SW issue or how you managed to get it to work properly ? Do you know whether y ou must use BIS or BES to get it to work or is a working WAP acces enough !??y
TUGAdmin
PostPosted: Wed Feb 02, 2011 10:02 am    Post subject: Reply with quote
HI mbenda,
Sounds like the problem is with your network connection mode.
We offer either a BES or a BIS version for download.
BIS is for users who purchased their device directly from an operator
BES is for users who get their BB from their enterprise IT department that maintains its own BES server.
If you only have a WAP connection on your BB - then neither of these versions will work for you.
We do have a version that works with WAP - but please send me an email so that we can set you up with that (please reference this post in the forum)
TUGAdmin
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
22.055 (29 May 24)
