Pocket GPS World :: View topic - CamerAlert Comes To Android
Goto page Previous  1, 2, 3 ... 8, 9, 10, 11, 12, 13  Next
AntonM
PostPosted: Mon Jan 24, 2011 12:59 am    Post subject: Re: Bug? Reply with quote
AntonM wrote:
MaFt wrote:
Can you email the logs to lutz AT pocketgpsworld.com
They can be found at:
sdcard\Android\data\com.pocketgpsworld\cameralert\files
My SD card does not seem to have a folder called com.pocketgpsworld in \Android\data\
Not wishing to spam or nag -- just didn't want this to get lost in all the other issues being raised here! Smile
Anton
PostPosted: Mon Jan 24, 2011 1:08 am    Post subject: Reply with quote
Enable the diagnostics option in the settings, and then watch the MB value while you zoom in.
Generally we are not too concerned about this issue as you're clearly doing couch testing, and the issue is a lot less likely in real road use.
AntonM
PostPosted: Mon Jan 24, 2011 1:22 am    Post subject: Reply with quote
I don't expect major problems either.
What bothered me more is that I should have "..\Android\data\com.pocketgpsworld\cameralert\files", but don't even have the "com.pocketgpsworld" folder on the "..\Android\data\" path.
I have enabled diagnostics, and watched the Mb change -- not sure what that should mean in relation to all this, though?
Anton
PostPosted: Mon Jan 24, 2011 1:43 am    Post subject: Reply with quote
For whatever reason zooming in on the map consumes a lot of MB (megabytes) of working memory. It will later be recovered by the garbage collector, but that is a rather lame thing and you can easily overpower it by hacking away at the zoom buttons.
No folder means that the application crashes in a way that doesn't even give it time to write a crash log. A bit like in "Mostly harmless".
PostPosted: Mon Jan 24, 2011 8:42 am    Post subject: Reply with quote
kevinx wrote:
Thoughts... "We" are seen as a "dot" on the mapping.
Can that not be changed to an "Arrow" in the direction of travel (cosmetic I know, but would save any confusion!).
Also, is it not possible to incorporate a timed (or manual) "dusk til dawn" functionality, to dim the display during general hours of darkness (+/-), similar to that of Google Maps inbuilt timing.
Neither are options available to us via the Google Maps API.
You mention 'similar to' but Google Maps has no night mode, only Google Nav which is an entirely separate application using vector maps rather than the bitmaps that are used in Google Maps.
Juniper
PostPosted: Mon Jan 24, 2011 9:16 am    Post subject: Reply with quote
Impressed with this app, having just driven from Bristol to Swansea. Particularly like the running average speed shown next to the instantaneous speed when travelling in an average speed zone.
I was puzzled by a stretch of indicated 30mph just before the A470 junction, when there were no speed limits in reality (other than national speed limit, obviously). I suppose it might have related to a neighbouring road, but it seemed to be telling me about it for about a minute.
PostPosted: Mon Jan 24, 2011 9:27 am    Post subject: Reply with quote
I expect this would be Truvelo:2126@30. This is something CamerAlert cannot avoid. It depends on your setting for the warnings, both the time of advance warning (I use 30 seconds, so the warning will last 30 seconds PLUS the post camera clearance time) and the arc you choose for the warnings to detect. Gatso:16029@30 at Reading always warns me on the eastbound M4. In my many miles, I find this a very insignificant factor, as I'm usually well aware that I'm on a motorway at national speed limit, so 30mph cameras are not relevant.
Juniper
PostPosted: Mon Jan 24, 2011 9:35 am    Post subject: Reply with quote
OK, thanks. Maybe I need to fiddle with settings. I am used to the neighbouring road alerts on my TomTom (with PGPSW alerts), and I do filter them out, but it seemed to be more insistent with CamerAlert, as if it was a hangover from earlier roadworks on the motorway.
PostPosted: Mon Jan 24, 2011 10:19 am    Post subject: Reply with quote
I was that way myself last Monday and didn't notice anything out of the ordinary. From recollection they never had a 30mph limit on the motorway there.
PostPosted: Mon Jan 24, 2011 10:28 am    Post subject: Reply with quote
it's a toss up between false warnings missed cameras.
you CAN adjust the angles in settings / advanced settings. for example you can reduce the angles so you only get cameras more directly in your 'line of sight' and not 'around the corner'. this would help in this instance as cameras to the side would have a higher chance of being ignored.
the downside of this when you are on smaller roads (not motorway) is that if you go around a slight bend and there's a camera then you may not have been alerted in time...
so, either you accept there will be some false positives or you reduce those with a risk of missing some proper alerts.
there's a better description in the FAQ's for the app here: http://www.pocketgpsworld.com/cameralert-android.php#faq
dazzabird
PostPosted: Mon Jan 24, 2011 12:06 pm    Post subject: Reply with quote
dazzabird wrote:
ok fairly new to this BUT...
Downloaded s/w to my Sony X10 and drove to work this morning..all ok..
Paid £19.99 about an hour ago for subscription...
How long after paying can i download full database ?
darren
Access is immediate upon payment, you should see status 'subscribed' in the Manage Cameras page of the app.
Our records show a handset associated with your account and a valid subscription. There is also a download at 19:23hrs so that suggests all is working?
Yeah seems to have downloaded now....Will have a drive later today and see what happens.
The london A13 is getting some new average speed cameras so that was my main reason..
many thanks
darren
kevinx
PostPosted: Mon Jan 24, 2011 8:11 pm    Post subject: Re: Used CamerAlert for first time and .. Reply with quote
lbendlin wrote:
kevinx wrote:
I thought it may have in fact been a "feature" of the graphic (slightly dreamy appearence)
Yes, this was done by our psychedelics department. Despair not, even in the new version you'll still see a slight hue of dreaminess, particularly on high resolution screens. Providing higher resolution graphics would inflate the application size too much.
"Wooooowwwwww. Cool man, I really dig it..." ;-)
Cheers buddy :-)
HTC OneX (IceCreamSandwich), HTC DesireHD (Gingerbread) Co-Pilot Premium, GoogleMaps+CamerAlert352
TomTomOne (Original with the faster processor!)
v7.903, o/s 2344, GPSv1.21 Boot 5.0500
Mv710.1561(W Europe)+Traffic, N82 connection to GPRS traffic
kevinx
PostPosted: Mon Jan 24, 2011 8:21 pm    Post subject: Reply with quote
Cheers Darren,
I consider myself to have had a severe wrist slap :-( (not fully understanding the API's etc..)
True enough it is the NAVIGATION of Google maps which incorporates "dusk til dawn" (just checked again), but I DID notice that the "marker" IS in fact a blue ARROW (within Google Maps, and navigation) as opposed to a blue dot...
(unless I am looking at the wong map data? - v5 #5014)
PostPosted: Mon Jan 24, 2011 8:33 pm    Post subject: Reply with quote
blue arrow is easy (and will likely make it into the next version as it also helps to improve performance). But the night mode stuff is a non-starter, just as Darren explained.
PostPosted: Mon Jan 24, 2011 8:39 pm    Post subject: Reply with quote
Oh well, one out of two ain't bad Smile (hadn't realised we could do the arrow).
Page 9 of 13
23.052 (14 May 25)
