Darren Frequent Visitor
Posted: Thu Jan 20, 2011 10:57 pm Post subject: |
TheQuest wrote: | So I have to ask similar to what I asked:- Here, do I install over the top, also there should be no need for me to select Unknown sources in applications because the app will [is now Known] be from the Market ? |
You should be able to install over the top and no, you do not need to have 'Unknown Sources' enabled now that this is an official app.
If you have any issues as a result of using the Beta and cannot install, open a support ticket and we'll clear the record of the previous install. _________________ Darren Griffin |
TheQuest Regular Visitor
Joined: Aug 15, 2010 Posts: 81 Location: Kent. UK by the sea
Posted: Thu Jan 20, 2011 11:43 pm Post subject: |
Hi Darren
Thanks for your reply.
Just tried to install it.
It says, Download and Installed successfully.
Then:- Instillation Error
Packed file was not signed correctly.
With regards
Take Care
TheQuest
PS:It says over on the AppBrain Market its installed.
PPS: and I have just received and email from PGPSW Quote: | Thanks for buying from PocketGPSWorld.com on Android Market! ..... | _________________ When Nothing is Certain, Anything is Possible. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15152 Location: Bradford, West Yorkshire
Posted: Thu Jan 20, 2011 11:54 pm Post subject: |
best thing to do would be to uninstall the beta version of the app and then redownload from the market.
not sure on your subscription status but if you have a subscription then you will be fine. if not then you will forfeit the single free download.
MaFt |
Posted: Fri Jan 21, 2011 12:12 am Post subject: |
Hi MaFt
Thank you for your reply.
Quote: | best thing to do would be to uninstall the beta version of the app and then redownload from the market. |
I will do so tomorrow.
Quote: | not sure on your subscription status but if you have a subscription then you will be fine. if not then you will forfeit the single free download. |
I have now have just less then:- 209 days, 12 hours, 1 minutes, 28 seconds.
With regards
Take Care
TheQuest _________________ When Nothing is Certain, Anything is Possible. |
Posted: Fri Jan 21, 2011 12:19 am Post subject: |
in which case, remove the app fully and reinstall afresh from market. you will need to reconfigure your preferences though.
MaFt |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Fri Jan 21, 2011 7:46 am Post subject: |
burtonian wrote: | What size is the app file and does it support moving to an sd card please? |
Not sure if this has been answered as just reading thro thread - but yes I've moved mine to the SD card.
desire 2.2
Cheers, Bob
edit by me.
The app is showing as 152 KB
Data 2.38 MB
Total 2.52 MB _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Fri Jan 21, 2011 9:42 am Post subject: |
3.62mb (plus 2-3mb for cached map tiles, settings and database etc)
and yes, it should work fine on sd card. pretty certain at least one of the beta testers did it that way with no issues.
MaFt |
speare Occasional Visitor
Posted: Fri Jan 21, 2011 10:38 am Post subject: Blackberry |
When Can we expect this ap for Blackberry Storm? |
scarymonkey Lifetime Member
Joined: May 09, 2007 Posts: 454 Location: Worcestershire
Posted: Fri Jan 21, 2011 10:40 am Post subject: |
MaFt wrote: | and yes, it should work fine on sd card. pretty certain at least one of the beta testers did it that way with no issues. |
Working fine from my SD card with no performance lag etc. |
burtonian Lifetime Member
Posted: Fri Jan 21, 2011 10:42 am Post subject: |
Thanks, 253 and MaFt, about to install on Wildfire |
grahama41 Lifetime Member
Posted: Fri Jan 21, 2011 11:23 am Post subject: |
Very good app. Tried it this morning and it works fine. A couple of questions:
I use Car Home as a car dock app whilst driving. When CameraAlert is running and displayed I get the audio warning and a very quick visual message but then no more warnings until the all clear. If I turn on overspeed I get the warning when over the limit plus the big speed graphic on the display. I would also like to see a distance countdown to the camera if possible please and I would also like to control how long the overspeed messages continue for as they seem to continue long past the camera.
Car Home auto starts / stops when a predefined Bluetooth connection pair is made. If CameraAlert could do the same this would be really useful. Any plans for this type of setting? How about when ac power is detected? Both would be very useful for automation. |
Posted: Fri Jan 21, 2011 11:29 am Post subject: |
grahama41 wrote: | I use Car Home as a car dock app whilst driving. When CameraAlert is running and displayed I get the audio warning and a very quick visual message but then no more warnings until the all clear. If I turn on overspeed I get the warning when over the limit plus the big speed graphic on the display. I would also like to see a distance countdown to the camera if possible please and I would also like to control how long the overspeed messages continue for as they seem to continue long past the camera. |
if you're not over the speed limit then we didn't see it as important enough to keep throwing up pop-ups with the distance remaining. if you're not speeding then there's no need to know 100% where the camera is? The 'all clear' will sound 4 seconds after the camera lcoation has been passed.
grahama41 wrote: | Car Home auto starts / stops when a predefined Bluetooth connection pair is made. If CameraAlert could do the same this would be really useful. Any plans for this type of setting? How about when ac power is detected? Both would be very useful for automation. |
you're not the first to suggest this. It is something we will probably look into once initial teething problems are sorted out and the iPhone version is brought up to date with the Android one (doesn't currently have pre-warning sounds or overspeed sounds). |
Posted: Fri Jan 21, 2011 12:09 pm Post subject: |
Thanks MaFt for the quick reply. I would find it better if the all clear delay could be configured. As it is, this morning I came out of a 40 limit (With camera at just before it ended) into a 60 zone and for a few seconds it was shouting 40 when it was clearly not needed so was very irritating. Personally I would prefer a 0 delay as even if the warning location isn't absolutely spot on, you'd be close enough to see the camera.
I look forward to seeing the automated options in future releases. It would make this good app "great". |
Posted: Fri Jan 21, 2011 12:18 pm Post subject: |
burtonian wrote: | Thanks, 253 and MaFt, about to install on Wildfire |
Installed, moved to SD card, linked to PGPSW account and database downloaded. Only minor issue was that I had to force close the app and restart before it stopped telling me the database was out of date. First impressions very good, will now have to find an excuse to go for a drive and see how it integrates with Google navigation :-) |
Solo Regular Visitor
Posted: Fri Jan 21, 2011 12:45 pm Post subject: |
Busy at this moment but two quick questions, does CA cover maps on Continent seamlessly, and how did you come up with 59p?(smile please).
Works well on SGS.
Thanks Brian,. _________________ Brian.
Mitac A701 TTN 5.21-2GB SD
Samsung Galaxy S
Samsung Galaxy S11
Samsung Galaxy s3
Galaxy s4
Galaxy s5
Galaxy tab s
The penalty for bigamy is two Mother-in-Laws |
