MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15393 Location: Bradford, West Yorkshire
Posted: Tue Jan 18, 2011 9:22 pm Post subject: |
AntonM wrote: | I googled "google maps night mode" and found I'm not the only one who has a problem with the brightness setting! But I note that Google Maps Navigation does have a night mode, which activates automatically when Google believes it's night at my location. So perhaps Google will soon release the how-to for developers? |
these are 2 very different things. basically the maps we use in our app (and indeed any maps powered by the android SDK) are bitmap files. we can only use what google make available which are simply the normal colour scheme for google maps. the gogle navigation renders it's own maps and roads (hence why the street names are always the right way etc).
AntonM wrote: | Your suggestion to use the "all clear" message is a good one, but I can't find a setting that lets me choose how close to (or far from) the camera the "all clear" is activated. Do the camera-ahead warning and the all-clear share the same distance setting? If they do, could they be given different settings? -- or have I missed something? |
the all clear is set in code to sound 4 seconds after passing a camera.
MaFt |
topbanana4 Lifetime Member
Posted: Thu Jan 20, 2011 3:05 pm Post subject: |
i,m trying to edit a mobile camera and don't understand the part where it say's ( on this side , on other side ) it would depend which way you were travelling. i can edit the camera on the website with no problem |
Darren Frequent Visitor
Posted: Thu Jan 20, 2011 3:22 pm Post subject: |
Is it on the side you were travelling when you clicked the report button, is was it on the other carriageway? _________________ Darren Griffin |
Posted: Thu Jan 20, 2011 3:33 pm Post subject: |
thanks for the quick reply. no it's a camera already in the database and want to edit it. |
Posted: Thu Jan 20, 2011 3:39 pm Post subject: |
But you can only edit cameras in-app that you have passed and reported. So the question 'This Side' or 'Other Side' applies. Was it on your side when you passed it or the other side.
If you haven't passed it, and you want to submit a change, you need to do so from the web-site submissions page. _________________ Darren Griffin |
Posted: Thu Jan 20, 2011 4:04 pm Post subject: |
if in doubt add a voice note along the lines of "it needs changing to the opposite direction to that which is already in the database" (or something more concise )
MaFt |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Thu Jan 20, 2011 9:52 pm Post subject: |
I note that on the CamerAlert user guide, you are continuing to perpetuate the myth:
"With this screen you can now specify which direction the camera monitors. Please bear in mind that some cameras (SPECs and Truvelo) take forward facing images and others take rear facing images."
Can I suggest that you remove the Truvelo from the examples of forward-facing cameras. Although it can (& regularly does!) take forward-facing photos, it can also take rear-facing photos. Constantly referring to Truvelos as forward-facing cameras gives the impression that they can only take photos of the front of the car.
Unfortunately, I know to my cost that this isn't true. I used to regularly pass a Truvelo on my way to work. I believed that it was only a forward-facing camera because I had read this so many times. I was therefore taken by complete surprise when I received an NIP showing a time when the camera couldn't have taken a picture of the front of my car - when I requested a copy of the photo, it clearly showed the rear.
I think this just goes to show that the continued references to Truvelos as forward-facing cameras are very misleading, and should be changed. _________________ Garmin DriveSmart 50 LMT-D |
TheQuest Regular Visitor
Joined: Aug 15, 2010 Posts: 81 Location: Kent. UK by the sea
Posted: Thu Jan 20, 2011 11:07 pm Post subject: |
Hi, Daggers
It says Here:- TRUVELO.
Quote: | Do not assume therefore that Truvelo's operate only in forward facing mode. |
Take Care
TheQuest  _________________ When Nothing is Certain, Anything is Possible. |
Posted: Thu Jan 20, 2011 11:17 pm Post subject: |
TheQuest wrote: |
Yes, but that's not on (or referenced from) the CamerAlert User Guide page. _________________ Garmin DriveSmart 50 LMT-D |
Posted: Thu Jan 20, 2011 11:24 pm Post subject: |
Duly noted.
I have changed it to
Quote: | Please bear in mind that some cameras (SPECs and Truvelo) can be installed to operate in forward or rear facing modes whereas others operate in rear facing mode only." |
Posted: Sat Jan 22, 2011 8:05 pm Post subject: |
Thanks Darren! _________________ Garmin DriveSmart 50 LMT-D |
Posted: Sat Jan 22, 2011 8:31 pm Post subject: |
Out of interest, do you know the CameraID of the Truvelo that caught you? _________________ Darren Griffin |
Posted: Sat Jan 22, 2011 9:44 pm Post subject: |
Darren wrote: | Out of interest, do you know the CameraID of the Truvelo that caught you? |
Yes - it was 5474 in the village of Farthinghoe, Northants. It's already marked as bi-directional. _________________ Garmin DriveSmart 50 LMT-D |
Posted: Sat Jan 22, 2011 9:55 pm Post subject: |
So had that camera been turned around to face SE or did it catch you as you passed it heading NW? _________________ Darren Griffin |
Posted: Sun Jan 23, 2011 1:56 am Post subject: |
I was travelling SE at the time (towards MK), though I have seen that camera pointing in both directions.
It has been quite a while since I passed that way, so I can't comment on its current situation. _________________ Garmin DriveSmart 50 LMT-D |
