tailz Occasional Visitor
Posted: Mon Jan 17, 2011 5:32 pm Post subject: 1690 can I delete specific Proximity Alerts? |
I have just purchased a Nuvi 1690 and used it today for the first time in a trip up the M1 past Nottingham. I have the proximity alerts switched on and as I reached the point on the M1 where the road works used to be passing Nottingham I got a warning about the 50mph variable speed limit cameras. Obviously these cameras have been gone for a while now, so I would like to remove them from the database, can someone explain if this is possible and how please? I have a quick butchers through the previous topics and could not see anything, so if I missed a previous post i appologise.
Tony |
Darren Frequent Visitor
Posted: Mon Jan 17, 2011 5:42 pm Post subject: |
If these are Garmin speed cameras then no, you can't manually edit them.
But, if you were to subscribe to our speed camera service, the data would be up to date - we have much better, more accurate, and more up to date speed camera data than the service Garmin use. _________________ Darren Griffin |
Posted: Tue Jan 18, 2011 4:35 pm Post subject: |
Thanks for the reply Darren, I will give some thought to subscribing to the camera database |
Posted: Tue Jan 18, 2011 5:08 pm Post subject: |
Feel free to peruse our submission map here. That should prove that our data is current, check the M1 roadworks cameras that are incorrect on your Garmin. _________________ Darren Griffin |
SQUARE2024 Lifetime Member
Posted: Wed Jan 19, 2011 10:27 am Post subject: |
tailz wrote: | Thanks for the reply Darren, I will give some thought to subscribing to the camera database |
There is no contest when it comes to what Data base to use _________________ Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV |
Posted: Wed Jan 19, 2011 5:18 pm Post subject: |
You smooth talkers..ok..off now to sign up. |
Posted: Wed Jan 19, 2011 5:52 pm Post subject: |
All done and signed up, just 1 question though,
I have downloaded both the UK and Euro databases, installed the UK one first, then changed the name from poi.gpi to UKpoi.gpi, then I loaded the Eur database and renamed that to Eurpoi.gpi. When I go the the proximity alerts settings on my nuvi, I just have the 1 Custom POI's option listed and ticked, is that correct or should I have 1 for UK and 1 for Eur?
Tony |
Posted: Wed Jan 19, 2011 5:56 pm Post subject: |
You should see two sets of categories. Browse to your device and confirm both .gpi files are still present. _________________ Darren Griffin |
Posted: Wed Jan 19, 2011 6:30 pm Post subject: |
I have renamed both gpi files so now I have eucams and ukcams still only 1 custom poi listing in settings but I am getting cameras showing up both in the UK and France so all appears well. |
Posted: Wed Jan 19, 2011 8:15 pm Post subject: |
Iirc you will only see one Custom poi category regardless of how many GPI files you have loaded. |
Posted: Wed Jan 19, 2011 8:23 pm Post subject: |
PaulB2005 wrote: | Iirc you will only see one Custom poi category regardless of how many GPI files you have loaded. |
Really? The sticky suggests otherwise but I don't have a Garmin to test - You've got it _________________ Darren Griffin |
Posted: Wed Jan 19, 2011 8:38 pm Post subject: |
Quote: | Really? The sticky suggests otherwise but |
Ah right. I did try it once seperating my non Speed Camera POIs from the Speed Camera POIs so i'm working from memory which is never a good idea in my case..... I think...
Quote: | I don't have a Garmin to test - You've got it |
At the minute you are significantly closer to it than i as my mum is using it.... Did you need it back? |
Posted: Wed Jan 19, 2011 9:07 pm Post subject: |
No, just pulling yer leg. _________________ Darren Griffin |
