rentalman Occasional Visitor
Posted: Sun Jan 09, 2011 4:02 pm Post subject: Best navigation software |
Hi can any one help
I recently purchased a china single din DVD/GPS etc etc with 7" tft screen and it has nav n go igo8 2008 version 8.0.044898 june 2008 on it
i need assistance on the following, what are the alternatives available as i used to be a tom tom supporter and can not find one , also is this the best and if not which one do you recommend as i need decent graphics, speed camera and loads of POI maybe thats why i liked tom tom, also need to change voice as well as direction icon likre on the tom tom
cab you please suggest alternatives, or soloutions for my igo 8 for poi and voice changes as well as more maps
thanks for all your time and assistance
regards
rentalman |
Posted: Sun Jan 09, 2011 4:25 pm Post subject: |
Don't bother with TomTom Navigator 7 for your China made double DIN nav/ radio as it doesn't work very well, you end up with no nav voice as the unit has inadequate memory to support the application.
Mine came pre-loaded with Route 66 but these days I have Sygic loaded to it which works very well and you can put third party POI files on as well as configure it for warnings as you approach a POI category - Mike |
aj2052 Frequent Visitor
Posted: Mon Jan 10, 2011 1:16 am Post subject: |
As a recent starter on Sygic and already using TTn7 I must agree,
for a TomTom supporter Sygic is an ideal alternative the display and controls are almost the same but with the benefit of more up to date maps bearing in mind that tt is not supported for most third party units, a major benefit if only using GB is the cost of it as a download drect from Sygic i.e. about 19 euros not sure if further discount is still available, so its peanuts,
Also agree with Mike about sounds, POIs and distances just as easy a TomTom but have to convert ov2 files but these can be batch converted in couple of minutes so you could possibly use all your old tt poi files if required. _________________ Moto G5s Plus, Sygic 17.4.8 |
Posted: Mon Jan 10, 2011 6:50 pm Post subject: Best In Car stereo based sat nav |
Thanks all for the posts and thaks for the advice, my unit ios a single din with motorised tft 7" screen, what other alterenatives are there in connection with sat nav software that is SD card based and can run on my china unit with the dedicated gps sd card reader
Thanks again all for viewing AND assistance |
Posted: Mon Jan 10, 2011 7:13 pm Post subject: |
Sygic, I-Go are about the only two that will work correctly with up to date maps.
TomTom Navigator 6 and Route 66 version 7 will both work but the maps are way out of date, the newer versions of both TomTom and Route 66 will not work correctly with the device.
One other possible contender is the Garmin software intended for use with their failed "Nuvi Phone" as that can be supplied on SD card but I have never tried it on my deck - Mike |
Posted: Mon Jan 10, 2011 7:29 pm Post subject: SD Installation |
Thanks for the reply
i asking as used to be a bit teckky but anyway the past should not be dwell on
What i want is to now is that if i go for any of the ones recommended, what compatibility version will i be looking for as my excellent bargain, fantasticish car head unit is unbranded as they say as china 1 din import. as you may see my dilema, do i just look for win CE 5.0 compatible or is it classed as a pnd or pda file format
Thanks again all
Posted: Mon Jan 10, 2011 7:34 pm Post subject: |
You won't find any software claiming Win CE 5.0 compliant, best bet is go for the software for the PDA devices as they use an OS which is the closest match - Mike |
Posted: Mon Jan 10, 2011 7:40 pm Post subject: Compliance |
Thanks again for the assistance
what PDA format or are they all the same, sounds silly but thoughts gps sofftware was compliant with different types of pda's not all
sorry if sounds silly question (Dummies Guide)
Thnaks again |
Posted: Mon Jan 10, 2011 7:41 pm Post subject: Suggestions |
Any recommendations or not allowed to product place |
Posted: Mon Jan 10, 2011 7:47 pm Post subject: |
I have already said whats installed to my unit earlier in the thread and works very well, there isn't too much PDA based software around these days as most companies have switched over to supporting the SmartPhone/ iPhone hardware, neither of which offer you a solution.
Look at Sygic for the PDA and see what you think, its easy to get used to and very similar in terms of menu and capability to the TomTom software you have been used to using - Mike |
Posted: Mon Jan 10, 2011 8:19 pm Post subject: Many Thanks |
THanks for your assistance
always |
