Pocket GPS World :: View topic - Ash 10 Camera Manager
Goto page Previous  1, 2, 3
dales
PostPosted: Fri Dec 24, 2010 4:55 pm    Post subject: Reply with quote
You might get some clues about what CameraManager has done (or hasn't done)
if you R-click on its icon, press Settings and select the Directories tab.
This should show you the date of issue of your latest database download, and the date CM last checked for updates.
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
Spaz
PostPosted: Fri Dec 24, 2010 5:26 pm    Post subject: nuvi 250 Reply with quote
thanks for reply, i have version 3 which does not work on my nuvi 250 does not do bmps only wav files, worked perfect with older camera manager 1.00.01 but thats says its expired and will not work, can i not get another copy of the old camera manager, i dont think v3 works wiyh a nuvi 250
Mal
PaulB2005
PostPosted: Fri Dec 24, 2010 6:39 pm    Post subject: Reply with quote
Camera Manager 3 works with ALL Nuvi units. Something is obviously wrong and we need to work out what.
BMPs are the icons. Some units don't work with MP3 files but you don't need those.
Have you configured the directories yet?
I would try closing CM and then move the files in your POILoader upload folder somewhere else. Restart CM and see if you can download the database.
Spaz
PostPosted: Fri Dec 24, 2010 7:33 pm    Post subject: Nuvi Reply with quote
Cheers lads
put wave files in
put sox.exe in
put cvs files in
put bmps in
all working on satnav camera manager changes date on directory when checked, the icon in task bar does not animate when checking probaly will when theres something to download.
THANKS FOR INFO AND MERRY XMAS TO YOU ALL
Spaz
PostPosted: Mon Dec 27, 2010 3:18 pm    Post subject: nuvi 250 Reply with quote
great nearly everthing works except when i make changes to CMit will not upatde them just trying to connect nothing after half an hour, restart CM still the same yet when you log off it say not logged on which means to me it was logged on but would not make changes
Mal
dales
PostPosted: Wed Dec 29, 2010 6:26 pm    Post subject: Reply with quote
There's a new PGPSW database out today.
See if Ash10 downloads it now (now that there's something for it to do).
If you R-click on the Ash10 CameraManager icon, you can select "Check now..." to force a check (if it seems unwilling to perform one itself).
Dales
tankerman10
PostPosted: Sat Oct 27, 2012 10:46 am    Post subject: POI Directory is not set Reply with quote
I've used various iterations of Ash10's Camera Manager for several years without problem. However, in the last few days it's begun to tell me the POI directory is not set. When I check the setting in CM I can see that a suffix has been added to the folder, which now ends \Speed Cameras~{w. If I browse to the location I can reset the directory so that the ~{w suffix disappears, and so does the warning. This lasts for only a short time, though, before the warning re-occurs and the suffix reappears.
Does anyone have any suggestions how to prevent this?
Page 3 of 3
22.124 (26 Dec 24)
