Pocket GPS World :: View topic - Rename file on SD card.
g0tch
PostPosted: Sun Dec 19, 2010 3:23 pm    Post subject: Rename file on SD card. Reply with quote
Ok, I’ve seen it, read it but cant remember how to rename file on SD card so that I can see which one I’m using. I did search but can’t find it. Can some kind soul please point me to it?
Kind regards and a Merry Christmas to all!
Tibor
Garmin Drivesmart 61
franb
Banned
PostPosted: Sun Dec 19, 2010 4:21 pm    Post subject: Re: Rename file on SD card. Reply with quote
If you mean renaming a new map then right/click on the map folder then rename and call it "my new map" or whatever.
Anita
PostPosted: Sun Dec 19, 2010 4:23 pm    Post subject: Reply with quote
Try here. Very Happy
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Sun Dec 19, 2010 4:26 pm    Post subject: Reply with quote
Can you explain what you want to do as its a little difficult to work out, there are loads of different things to rename to get different features/ capability, if its not renaming the map name but something else can you explain what you want? - Mike
g0tch
PostPosted: Sun Dec 19, 2010 5:21 pm    Post subject: Reply with quote
Mike, I’m sorry if I wasn’t too clear what I wanted to do, but Anita pointed me in the right direction. I have now bookmarked that page and hopefully will be able to tell if I’m using the internal memory or the card.
Thank you Anita and Mike for looking at my post.
Kind regards,
Tibor
franb
Banned
PostPosted: Sun Dec 19, 2010 8:06 pm    Post subject: Reply with quote
ONLY if you change/rename the map folders.
Changing the .pna won't help if both map folders are called:-
Western_and_Central_Europe
PostPosted: Sun Dec 19, 2010 8:20 pm    Post subject: Reply with quote
Are you sure, franb?
The way I have always done it in the past has been to open the .pna file with Notepad and to just edit the first line.
It should read something like "ID=Western_Europe.pna", but you can edit the "Western_Europe" bit to whatever you like (to "ID=Western_Europe_v860.pna" for example).
There was no need to change the folder names.
But things may have changed since I did it last....
g0tch
PostPosted: Sun Dec 19, 2010 8:24 pm    Post subject: Reply with quote
Thanks franb,
So if I rename the Western & Central Europe map folder on the sd card to something else, when I want switch map it will work with the new name? Assume then that I will also have to alter the .pna file within to the same name.
Tibor
PostPosted: Sun Dec 19, 2010 9:46 pm    Post subject: Reply with quote
I can confirm to you both that you do NOT need to change the folder name.
As a test, I just put my old v855 Western and Central Europe map back onto an SD card in my Go940.
That map folder and the new v860 map folder (on the internal memory) are BOTH called Western_and_Central_Europe.
All I did was change the first line of the .pna file of the old map as I described above.
I changed it to
ID=Western_and_Central_Europe-old!!.pna 1224205559 855
And sure enough, when I go to the "Switch map" menu this is what I see...
I can switch between them and confirm that I have by checking the version numbers in the info/status screen.
Remember, both map folders are still called Western_and_Central_Europe.
PostPosted: Mon Dec 20, 2010 12:46 am    Post subject: Reply with quote
Does TT allow two folders with the same name then? Shocked How wierd
Anita
PostPosted: Mon Dec 20, 2010 1:20 am    Post subject: Reply with quote
Not weird if one folder is in internal memory and the other is on an SD card. Confused
Anita
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Mon Dec 20, 2010 10:01 am    Post subject: Reply with quote
2/10. 100 lines 'I must pay more attentiom' Embarassed
Anita
PostPosted: Mon Dec 20, 2010 10:07 am    Post subject: Reply with quote
Drop them round to me when they're done, please, and no excuses about snow and ice on the A259! Wink
Anita
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Mon Dec 20, 2010 10:31 am    Post subject: Reply with quote
Another 100 lines for spelling.... Twisted Evil
g0tch
PostPosted: Mon Dec 20, 2010 11:51 am    Post subject: Reply with quote
Thanks all, will have a go later today.
Tibor
