Pocket GPS World :: View topic - TomTom 910 RDS-TMC stops scanning (freezes).
Goto page Previous  1, 2
MarkMarkB
PostPosted: Thu Oct 15, 2009 6:47 pm    Post subject: Reply with quote
All very interesting stuff.
From what I understand from the other post, there is not a similar improvement to be had for a 930T.
Or does soemone know better?
DeLorean
PostPosted: Thu Dec 17, 2009 5:46 pm    Post subject: Reply with quote
Ive been using the tweaked mctx.dat file (set to 1110) for some time now.
Its far superior to the old 2220 setting and it works as equally well on the continent Smile
1) Far more traffic information (nation wide).
2) More precise traffic information.
3) Nearly always connected to TMC broadcasting radio station.
My TMC-RDS still seems to jam every now and again, but I guess Ill just have to live with the problem.
🔸🔸 Currently using TomTom GO 940 & Locus Map 🔸🔸
alanlakes
PostPosted: Tue Dec 14, 2010 2:30 pm    Post subject: Reply with quote
Just got a RDS-TMC receiver for my 910 and had bookmarked the post for this very day! Can someone please help me, do I delete the string of text/icons in the mctx.dat file and replace with 11110 or do I put 11110 somewhere else?
Thanks Alan
Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker.
DeLorean
PostPosted: Tue Dec 14, 2010 10:34 pm    Post subject: Reply with quote
Hi Alan,
You're on the right track Smile
Open the mctx.dat file in Notepad or similar and change the string 2220 to read 1110.
Save the file over the top of the original mctx.dat file and off you go.
Since changing this setting my RDS-TMC adapter has been fantastic!
It's made it so easy to travel around Europe since it's now so accurate Smile
Iv'e been warned (verbally & icon) of snow, fog etc and recently even received a warning for escaped cows on an autobahn I was travelling on in Germany!
alanlakes
PostPosted: Wed Dec 15, 2010 7:07 am    Post subject: Reply with quote
Hi DeLorean
Thanks for prompt reply.
Still a bit confused as the string in my mctx.dat file is
TX01CVε .PQ'ξVN$dydGz~z
22220 string does not appear to be in the file.
Do I delete the string (TX01CVε .PQ'ξVN$dydGz~z) and replace with 11110 or is it 1110?
Thanks Alan
DeLorean
PostPosted: Wed Dec 15, 2010 9:15 am    Post subject: Reply with quote
Hi Alan,
this is because the mctx.dat file on your TomTom is the wrong version Sad
This isnt your fault; this is due to a TomTom cockup Shocked
The v7.900 & v7.903 Navcore updates install the wrong version of the mctx.dat file!
The best way to correct the issue is to copy the mctx.dat file from one of your backups before the Navcore was updated and edit that file.
Have a look at this tread: www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=71469&postdays=0&postorder=asc&start=30
Let me know if you need any more help.
Have fun Very Happy
alanlakes
PostPosted: Wed Dec 15, 2010 9:49 am    Post subject: Reply with quote
My last two backups (which is all I keep - in future I will keep them all) have the same corrupted Mctx file!!
I have left mctx.dat file with only the string 11110 in it and have deleted everything else.
Do i still need to delete the gns file?
Thanks Alan
DeLorean
PostPosted: Wed Dec 15, 2010 4:39 pm    Post subject: Reply with quote
Deleting the gnsdata file in the gns folder wont do any harm.
This file is automatically recreated when your TomTom next receives TMC data.
Personally I would delete it on this occasion as youre tinkering with the way your TMC works Very Happy
Robin2
PostPosted: Thu Dec 16, 2010 3:54 pm    Post subject: Reply with quote
I was intrigued by this thread so thought I would give it a try on my 720. I removed the existing mctx.dat file (and saved it to my desktop!). As described by others, it contained a string of gibberish characters.
Using notepad I created a new file containing only 11110 and renamed it to mctx.dat I then copied it into my TomTom and the RDS-TMC works fine. I can't yet say that it works better as I haven't been into the areas where I used to lose signal, but it certainly seemed to pick up its first lock quicker than usual.
I haven't burnt my boats though, as the version of TomTom which i have modified is on a 4GB SD card containing the full Western Europe map. The device itself also contains the latest Navcore, plus the Western zone WE map. If it plays up on the road later, I'll just remove the SD card until I get home
Thanks for the tip
Robin
Satmap Active 10
DeLorean
PostPosted: Thu Dec 16, 2010 6:15 pm    Post subject: Reply with quote
Interesting....
I was led to believe that it didn't work on the newer Navcores/units Shocked
On the old setting it only picks up TMC from Classic FM station which is flaky at the best of times.
On the new settings it should get its TMC info from all over the place and should stay pretty much connected all of the time.
I find that when you hit Poland, Slovakia etc (e.g. Central Europe) it becomes very intermittent again.
I havent tried going back to the 22220 setting when this happens, perhaps the old setting would work better in these countries?
I can try this in January when I drive back to Slovakia.
Robin2, you should be able to see the RDS frequency it's locked onto at the bottom of the Traffic menu.
Let us know how you get on Very Happy
Page 2 of 2
23.012 (08 Jan 25)
Terms & Privacy
