Bioniccarrot Occasional Visitor
Posted: Sun Dec 12, 2010 11:04 am Post subject: mapsetting.cfg file |
can anyone tell me where to find the updated mapsetting.cfg file.
I have read the documetation and cannot find a link to the file, It does say that ( I will replace the paragraph with a link to the correct mapsettings.cfg file directly). Sorry to be a pain but i feel like i am playing hunt the thimble. That should give you a clue to my age. |
Posted: Sun Dec 12, 2010 11:28 am Post subject: |
On the page that contains the instructions on how to get the speed cameras on the TomTom iPhone app is a download zip file link, click this and it will contain a full set of ready to use sound files, icons and the necessary mapsettings.cfg file - Mike |
Posted: Sun Dec 12, 2010 11:36 am Post subject: mapsettings.cfg |
Hi Mike, thanks for your help will go back to the begining, in the 3rd column it shows a mapsettings. cfg file without stating for the obvious answer where should i put it |
Posted: Sun Dec 12, 2010 11:57 am Post subject: |
Do you mean where to put the file with respect to this screen shot:
If so its still in the TomTom folder but goes under Documents/ [MAP NAME] you should be able to see the location from the three views shown above in DiskAid when read left to right. Note if you have Europe rather than UK&ROI then some of the folder names will reflect this difference, but the same files work with either version - Mike |
Posted: Sun Dec 12, 2010 12:09 pm Post subject: mapsettings.cfg file |
Hi Mike, i have gone through the downloaded zip file and i cannot see any config files. I have tried following the instruction, i have got to renaming files and transferring to device, next is download the elusive mapsettings.cfg etc and can go no further. Could it be this was never designed for ludites |
Posted: Sun Dec 12, 2010 12:15 pm Post subject: |
mapsettings.cfg is certainly in the download, perhaps your computer isn't set to display file extensions in which case the file would be named mapsettings.
Either way I have sent you a set of files including the mapsettings.cfg file via e-mail which you should have by the time you are reading this? - Mike |
Posted: Sun Dec 12, 2010 12:36 pm Post subject: Mapsettings.cfg |
Hi Mike , got the files with the mapsettings.cfg, thanks for that, i can only assume as i have transferred files to device somewhere on my iphone i should find these alerts. If I buy the pocket gps app will it make life easier |
