Pocket GPS World :: View topic - Average speed display not clearing
philjs
PostPosted: Wed Apr 07, 2010 10:56 am    Post subject: Average speed display not clearing Reply with quote
I noticed yesterday that if I follow the A414 eastbound via the A1M then CamerAlert does not spot that I have left an average speed camera zone on the first slip north of the Hatfield tunnel. Continued to show an average speed until I reset the app next time I stopped driving.
PostPosted: Wed Apr 07, 2010 11:14 am    Post subject: Reply with quote
so, driving north on the A1M, turning off onto the A414 at J4?
if you redownload then this should be fixed.
thanks
ps - you can press the 'speedo' button at any time to manually start/stop the average speed.
hairy_bob
PostPosted: Fri Dec 10, 2010 3:40 pm    Post subject: Still a problem on M1 north of M25 Reply with quote
I have had this same problem last week driving through a long stretch of 50mph average cameras on the M1 (the roadworks just north of the M25), it does not realise when the restriction has ended & there is no easy way to submit an "end of restriction" to be included in the database. I think this was on v1.2.1 (I've now upgraded to 1.2.2).
RavingDave
PostPosted: Fri Dec 10, 2010 4:06 pm    Post subject: Re: Average speed display not clearing Reply with quote
You can just tap on the 'average speed' number which will clear it, without having to reset the app
PostPosted: Fri Dec 10, 2010 4:37 pm    Post subject: Re: Still a problem on M1 north of M25 Reply with quote
You can either submit the end specs with a note or email cameras[at]pocketgpsworld.com and explain the issue.
SpikeyMikey
PostPosted: Fri Dec 10, 2010 5:52 pm    Post subject: Reply with quote
The average speed monitoring does not cancel if I leave at J20 M25 north for A41 Aylesbury, mid SPECS zone, and I have to manually stop it by pressing the speedo button.
Shouldn't the distance / alerting setup realise I have left the zone and cancel the monitoring?
Mike
PostPosted: Fri Dec 10, 2010 5:59 pm    Post subject: Reply with quote
Yes but no-one is perfect. If we don't have an 'END' camera recorded as such then this happens. Report it and we will fix it.
SpikeyMikey
PostPosted: Fri Dec 10, 2010 6:17 pm    Post subject: Reply with quote
Thanks for the reply Darren, but as far as I know the SPECS zone continues north around the M25 therefore the camera I pass on exit is not an END one, it's just that if I leave the zone part way, for example at J20, the average speed monitoring continues until I cancel it.
Mike
PostPosted: Fri Dec 10, 2010 6:31 pm    Post subject: Reply with quote
Yes, but where it's possible to exit an M-Way mid way through a set of SPECS, we add an exit marker to cancel the average speed calcs. So if we have missed one, we need to know.
SpikeyMikey
PostPosted: Fri Dec 10, 2010 6:34 pm    Post subject: Reply with quote
RIC Smile
Mike
PostPosted: Sat Dec 11, 2010 12:26 am    Post subject: Reply with quote
should now be fixed. if you download the database again in the app then these points will be included.
