sailerman1951 Occasional Visitor
Posted: Thu Nov 04, 2010 11:47 am Post subject: speed alert database |
Hi trouble accessing the speed cameras on my nuvi 490t, they download ok, and load on to my device but they do not appear on the maps, I have tried switching off the garmin database but nothing changes,
mike |
![](modules/Forums/images/avatars/gallery/Sphere_animated2.gif)
Posted: Thu Nov 04, 2010 12:12 pm Post subject: |
How are you loading them to the device?
Are you following the instructions here?
Have you enabled Custom POIs? |
Posted: Thu Dec 09, 2010 9:07 am Post subject: speed cameras on garmin nuvi |
have followed instructions to the letter, have also removed and re installed, they show up as custom POI, have tried de activating garmin ones and i just get no speed cameras at all |
Posted: Thu Dec 09, 2010 9:10 am Post subject: |
Are you testing this in the real world by driving or just looking at the map?
Best to test it by driving. |
Posted: Thu Dec 09, 2010 9:56 am Post subject: speed cameras |
Hi yes did a 100 mile run, only cameras that show are the garmin ones, switch those off and no cameras, used the database on my previous two units, one tom tom and a garmin with no problems |
Posted: Thu Dec 09, 2010 10:22 am Post subject: |
Hmm. There hasn't been a Garmin model the database doesn't work with so far and quite a few members have the 1490 and no compliants it doesn't work so far....
Just to check...
- you are downloading the Garmin POILoader database?
- you are located in the UK and you have chosen the UK database and not the European one?
- if you know the location of a camera if you zoom in on the map right up to it does it show?*
- you are using Garmin POILoader to install the speed camera database in Express mode?
- once you have loaded the speed camera database you are NOT then loading any further POI files such as Supermarkets and Petrol Stations etc?
* Not sure if you can still do this with the latest models... |
Posted: Thu Dec 09, 2010 12:41 pm Post subject: speed cameras on garmin nuvi |
seem to have tried most things suggested except zooming in to a camera, when installed if i open my garmin on the comp where should i find the cameras? and what will they be called? in POI i can find some but the file is very small |
MaFt Pocket GPS Staff
![](http://maft.co.uk/avatars/pgpsw.jpg)
Joined: Aug 31, 2005 Posts: 15158 Location: Bradford, West Yorkshire
Posted: Thu Dec 09, 2010 12:49 pm Post subject: Re: speed cameras on garmin nuvi |
sailerman1951 wrote: | they show up as custom POI |
so they've installed correctly then. can you go to: settings / proximity alerts and make sure that 'custom poi' is ticked?
MaFt |
Posted: Thu Dec 09, 2010 1:42 pm Post subject: |
Quote: | when installed if i open my garmin on the comp where should i find the cameras? |
All you will see is a file called POI.GPI in the Garmin/poi folder
Quote: | in POI i can find some but the file is very small |
Then they are loaded. However Garmin units only show you the POIs closest to your location hence the short list. I can't remember if it's the closest 25 POIs or if it's all POIs within 25 miles.... |
Posted: Thu Dec 09, 2010 2:17 pm Post subject: |
closest 25 (or maybe 40?) as opposed to within a certain radius.
MaFt |
